I am very interested to know if anyone has used teflon on there sway bar and what the results were. I got the idea from a subaru forum I was browsing through (to find ideas about what grease to use), and lots of those guys said that they dont use any grease on their sway bars, just teflon plumber's tape and they've never had problems with squeaks
Cole |
hahaha, well seeing as though I have been with this site the longest, and always get good feedback and seem to get my projects finished, I'll stick with the grease. I went to autozone and they had a bunch of value stuff I've never heard of, so I picked up the one thing that I have heard of. It's called Green Grease. So far I've only used it to grease the sway bar bushings, and a little on the end links
I use a silicone based grease (Sil-Glyde) on suspension bushings and swaybar mounts and links. For the ball joints, tie rod ends, and anything else with a grease zerk, I use a high pressure moly grease.
Using Sil-Glyde instead of grease in the bushings would be especially important if the bushings were rubber, as contact with petroleum based grease can cause rubber to degrade prematurely. Since you are using urethane bushings, it's maybe not that big of deal, but the silicone grease is nice because it's transparent and thick and stays where you put it. Hope this helps..... |
| were can i get ball joints | rtyauch301 | Suspension - Brakes - Steering | 6 | 09-02-2009 01:30 PM |
| Ball joints for MII? | BobbyG-39 | Suspension - Brakes - Steering | 15 | 07-24-2008 04:40 PM |
| Ball joints... | Rickrak77 | Suspension - Brakes - Steering | 5 | 10-26-2006 12:05 AM |
| Ball Joints....not a hot rod but.... | screamin340 | Suspension - Brakes - Steering | 7 | 08-05-2005 03:51 PM |
| Ball joints - all at once? | Stinkin_V8 | Suspension - Brakes - Steering | 9 | 05-30-2003 10:02 AM |
