What grinder needed for a shrinking disc - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2005, 03:02 PM
What model of grinder do I need? I see that milwaukee makes several grinders. Does it depend on the type of shrinking disc, Ive decided to go with the disc offered by John Kelley
Model 6086 is a 7-9in with 15amp, 4.0hp and 6000rpm
Also make a 7in model with 15amps and 5000rpm
Am leaning towards the 6086, Ive searched past posts and found nothing. Thanks...Eric
Old 02-26-2005, 03:14 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Grinders
Milwaukee makes good tools..I think I would lean toward the 7-9 in model myself..can't have too much power if you are doing any serious metal mowing..should run the shrinking disc just fine..
OMT
Old 02-26-2005, 06:59 PM
Randy Ferguson's Avatar
Ferguson Coachbuilding
Last journal entry: '41 Chevy sedan
The 6086 is the one you want. 6000 rpm is recommended.
Randy
Old 02-27-2005, 08:52 AM
Shabby chic sheet metalshaper
Yes, the bigger the better, but you can shrink with a 3400 rpm sander/polisher...just takes longer to build up the heat. The upside with a smaller unit is that it is cheaper and lighter weight...those big Milwaukees are heavy!
John www.ghiaspecialties.com
Old 02-27-2005, 10:19 AM
Guys thanks for info!!
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
my doors got stretched nomad57ry Body - Exterior 17 12-02-2004 06:51 AM
Shrinking disk adtkart Body - Exterior 19 05-23-2004 06:47 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
Shrinking Disc primerbaby Body - Exterior 1 03-30-2003 07:11 AM
