We're winning the case!
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 07-15-2003, 05:27 PM
oldred oldred is offline
what grit?
This may seem like a dumb one to you pros but I need to know what grit paper to use before spraying sealer. What I have is six year old acylic enamel that has been sanded with 220 grit and primed with two coats of dupont 131 fill-and-sand that has been sitting for nearly two months.The plan is to sand,seal and paint with dupont sealer and BC/CC. This is my pet project(65 mustang)that I have driven for six years with what looks like a cheap paint job(it is!) I want to get it right this time!
Old 07-15-2003, 06:44 PM
all fired up's Avatar
all fired up all fired up is offline
I use PPG so I am not sure about your products but I would say that you will want to finish sand with at least 320 grit.
Old 07-15-2003, 09:10 PM
Halloweenking's Avatar
Halloweenking Halloweenking is offline
Fantastically cannibalistic!
400 is fine as well as long as you aren't going to put any fillers over it. anything 300 and above up to 400 is fine. Nothing above 400 untill you get to the final paint.
HK
Old 07-15-2003, 10:09 PM
lostn50s lostn50s is offline
New Member
If your ready for the sealer than it stands to reason that you are done using any fillers of any type. The sealer is applied just prior to the paint finish, which in your case is BC/CC. For final sanding prior to seal coat, we use 360 grit 3M. 360 or 400 will give you the finish you are looking for prior to paint. I don't care for 320 especially if used wet as it is a bit coarse but will work if you are using a high-end sealer like PPG or Dupont. Hope this helps!
Rob :p
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
