What grit? before and after epoxy sealer ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2005, 11:10 PM
What grit? before epoxy sealer and after?
Guys, first of all thanks for answering my questions about this sanding questions.
If I use epoxy as a sealer on top of the 2K;
Should I finish the 2K primer 600 wet before epoxy?
And after epoxy sealer,
Should I 600 wet sand the epoxy and top coat?
This sanding grits on diffrent stages confuses me. I need your guidenes.
Thanks as allways.
Old 08-15-2005, 11:53 PM
Last journal entry: metal finish
sand the 2k with 600 if you want then spray the sealer and then ur base then clear... you dont have to sand the sealer its not suggested that you do that.
Old 08-16-2005, 06:38 AM
If you're using the epoxy as a sealer and only apply one coat then yeah just spray your color directly with no scuffing. Ususally spraying over uncured epoxy will cause a small amount of gloss dieback but nothing to be concerned about.
If you have the time to wait and want a better as sprayed finish then apply two coats of epoxy sealer and let it cure completely- should take 3 days to a week, then lightly sand with 600 or 800 grit and lightly scotchbrite any non sandable areas and apply your paint. Shooting over cured epoxy always gives a better as sprayed gloss with no dieback problems. JMO, there's many ways to skin a cat.
You can also paint directly over your 2K without using a sealer as well but cured and sanded epoxy IMO makes a much better surface with a better solvent barrier than urethane surfacers. Some urethane surfacers are more prone to absorbing solvents than others.
Old 08-16-2005, 10:33 AM
what about when you still have some body work to do? I recently shot a trunklid with 2k epoxy primer. It came out very slick and glossy. How is body filler going to stick to a fully cured epoxy surface? I still have some pings to fix.
What about older areas where the finished has chalked? What steps should I take to prep it for my body filler to stick?
Old 08-16-2005, 11:36 AM
rrmccabe's Avatar
GM Muscle
Something like a trunk I would give a quick scuff regardless. Since you have a few dings to fill you have not done your filler primer work anway and by time you get the bondo work done, fill primer and blocking and ready to seal, you will probably be near your epoxy maximum window anyway. So when in doubt sand.
As far as the chaulking other peices, this is UV damage. Not a big deal, but you cant paint over it. Sand it with 320-400 to get that layer off and re epoxy it.
When you are done with the sealer I like Bobs method from above. Two coats and then sand with 600. Let sit a couple days and paint. I think this makes for the ultimate seal job. Just my opinion of course
Rich
Old 08-17-2005, 10:27 PM
Bob, 600-800 wet or dry?
Old 08-17-2005, 10:31 PM
rrmccabe's Avatar
GM Muscle
I am not bob
But fresh epoxy does not sand that well dry. Wet with a little soap works best.
See what Bob says but I bet he will agree. If not, go with what he says. Hes the man !
Rich
Old 08-17-2005, 11:04 PM
Thank you Rich for the quick replay. I tought so need wet sanding. But hey I'm trying to not to make mistake.
