what grit hone for a rering job with moly rings - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2012, 03:40 PM
i was thinking in the niebor hood of 320-400 grit.
this is for my buddies turbocharged v6 camaro,he ended up breakng the 2nd ringland on one piston. for now he is rebuilding it as cheap as possible.
6 new speedpro pistons quick hone job to get the rings to seat not the best way to do it but it will get the car up and running for now
Old 09-20-2012, 05:29 PM
BigEd36's Avatar
From what I've seen different ring manufacturers recommend anywhere from 240 to 400 grit. Hastings Piston Rings recommends 220 - 280 grit for all 3 ring types (cast iron, moly, or chrome)
Cylinder bore refinishing
Old 09-20-2012, 06:00 PM
BigEd36's Avatar
Here's some info from EngineHones.com: Technical information on using engine hones, flex-hones, ball hones
The Following User Says Thank You to BigEd36 For This Useful Post:
Project89 (09-20-2012)
Old 09-20-2012, 06:22 PM
Originally Posted by BigEd36 View Post
thanks guys looks like i was right on the 320-400 grit, its just been so long since ive done this type of repiar i wanted to be sure . my main concern was using to coarse of a flex hone and making the bore to large and having to loose of a piston to wall clearance
Old 09-20-2012, 07:07 PM
BigEd36's Avatar
You would wear your arms out before you could remove enough material with a flex-hone to make the bore oversize!
Old 09-21-2012, 08:24 AM
Agreed, FlexHone CAN'T remove an appreciable amount of material, nor will it change the "shape" of the hole.
It is highly recommended, unless the cylinders are rebored, to use a "power hone" or "rigid hone" for moly rings. Molys have a hard time "seating" in bores that aren't "round". ANY taper or out-of-round will inhibit that. Iron rings are recommended if not reboring.
We use a Sunnen "625" stone for most moly applications. Higher level "race" engines get 820 and a "plateau" hone. Iron rings get "525". I don't think these numbers represent the actual "grit", but those are Sunnen's numbers. NOBODY knows more about "honing" than Sunnen... (:-
Jim
Old 09-21-2012, 04:11 PM
Jim
bores have been checked and are not out of round so should be ok, would really hate to pout cast iron rings back in this thing as they break way to easy in a forced induction engine
Old 09-23-2012, 08:49 AM
We've successfully used plasma-moly "file-fits" when things vary ever so slightly. You can "plate-hone" it again and have a tad more piston-to-wall without really hurting anything. Set the gaps accordingly and as long as you don't get TOO crazy with clearance, it'll be fine. Adding a graphite coating to the piston can add about .0005". Even in a "budget build", wall finish and ring prep are just about the most important aspect of a "blown" application.
You didn't say which V6. 3.1? 3.4? 3.8?
Jim
Old 09-23-2012, 05:29 PM
CNC Blocks Northeast
Bores should be checked with a head bolted on and measure from the pan side or bolt a torque plate on and check as that what your rings will see once the heads are bolted on.
Old 09-24-2012, 08:08 AM
t-bird60
hone
with the moly rings, you want a smooth cylinder. I use a sheet of 600 wet or dry sandpaper wrapped around the stones of the hone.(the 3-legged type). I put the oiled sandpaper in the cylinder, then put the hone inside of the paper. anything coarser will chew the moly off. Lets face it, a ring job is not a lasting solution, although I have done it many times and works fine. Check the top ring gap at the very top of it's travel in the cylinder. If too wide, it'e going to have some blow-by. I had my own engine rebuilding shop for several years. and am just sharing what I learned.
Hastings Plasma-Moly Ring Hone y2k600f4 Engine 5 04-23-2009 06:13 PM
Cylinder Honing - Flex Hone Grit Number - Help leejoy Engine 16 01-25-2008 12:58 PM
chrome moly or plasma moly rings? SBCfan04 Engine 5 01-19-2008 03:05 PM
piston rings to use on a rering job grumpysdeuce Engine 4 11-26-2006 08:06 PM
special hone for moly rings? VEGA 3503508.5 Engine 6 05-20-2006 10:10 AM
