what grit of paper to use between clears - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2012, 06:26 PM
55paneltrk.'s Avatar
Hello, ive just gotten 3 coats of clear on my project last night. I would like to put on another 3 coats. Was wondering what grit to use to scuff it down. Thank you for your time.
Old 10-05-2012, 08:15 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
are you going to wet sand or sand with a da? With a da I would use 1200. if I were to wet sand maybe 1000 or if you feel brave 600-800.
Old 10-05-2012, 08:24 PM
novafreek6872's Avatar
Nova Guru
Just trying to learn here... I have read that anything above 600, you can have adhesion problems. Not the case?
Old 10-05-2012, 08:33 PM
800-1000 and you will be good,We have sanded blend panels up to 1500 with no adhesion problems at all
Old 10-05-2012, 08:46 PM
Nova Guru
Makes sense, thanks.
Old 10-06-2012, 05:32 AM
ok thanks. i will be wet sanding it. I have heard to polish it you start with 600 and work your way up to 2500. so the 600 would be to much just for between the 3 coats of clear?
Old 10-06-2012, 06:37 AM
Nova Guru
Probably, but if the orange peel is bad it might be a good idea.
As for colorsanding after, depends what kind of finish you are looking for. Are you looking for a super flat, perfect show finish or just a very nice paint job?
If you want it dead perfect flat, start with 600 and work your way up.
I did mine and was able to just use 1500/ 2000 then buff... but it all depends on what you are looking for. With 6 coats of clear you will have enough material to do what you want.
Old 10-06-2012, 07:05 AM
deadbodyman's Avatar
Wiki Edits: 11
I like 600 dry DA with an a soft interpad much better than wet sanding.You'll prodably want to let cure for a while at least three days and re tape and paper.
Wet Sand paper and Dry Sand Paper taylorb2053 Body - Exterior 5 07-20-2011 11:57 AM
Sand paper grit question shad9876 Body - Exterior 1 08-03-2008 10:20 PM
Paint Prepping what grit paper for primer stages? camaro freak Body - Exterior 4 04-29-2007 09:06 AM
Mixing Clears PimpJuice Body - Exterior 17 09-06-2005 12:59 PM
