What Grit For Sanding Paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2005, 07:50 AM
I have a 66 Mustang Fastback that has been in storage for a long time. Instead of using chemicals I want to take the original paint off with a DA. Some of the paint has surface rust on it. There is very little pitting but some (light pitting) in a few different places. What grit pad would you recommend doing this with? Should I start with a course grit and finish with a finer one?
Thanks in advance
Danny
Old 09-19-2005, 09:54 AM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
start with 36 grit and work up to 80 before you epoxy it.... Keep your speed slow as heat will warp panels
Matthew
Old 09-19-2005, 10:32 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
I would try 80 first and see how well it cut if this is OEM paint only.
36 will get it done but I only go that radical if the 80 dosen't "cut it" so to speak. It's a lot more work to bring 36 up to 80 and I'm all for less work.
Point being,It takes say 2 day's to 36 it and then another 2 day's to bring it up to 80 for epoxy. vs. 2 1/2-3 day's to use 80 and be done. JMO.
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 12:33 PM
Need advice on a paint job tishmomo Body - Exterior 36 01-15-2008 11:19 AM
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 09:26 PM
This is interesting. Temporary peel off paint. kenseth17 Body - Exterior 5 08-11-2005 09:41 PM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 06:31 AM
