What happens if you overfill your trans? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2007, 12:08 PM
JJ350's Avatar
I posted a question the other day as to why my truck takes off when I put it into gear. I haven't had time yet to look into it, but I did check the oil this morning and noticed it looked like chocolate milk. I just changed the oil last weekend. Any way this brings me to think I overfilled the trans when I changed the trans a few months ago forgetting to drain the fluid it already had in it before putting fresh fluid in. I'm assuming the engine is sucking trans fluid threw the line that goes to the modulator down the intake?? So just curious as to what actually happens when a person over fills a trans.. thanks.
Old 05-24-2007, 01:23 PM
While chocolate milk is tasty and good to drink, fluid that looks like chocolate milk is not good. [ to drink or for your trans ].
First, how much over full is it [ do you not have a dipstick? ]
Second, what type of trans is it, some transmissions are very sensitive to too much fluid. Such as the thm400.
A little over may not be a problem, but too much will cause all sorts of problems, on some units.
Have you pulled your vacuum line off, at the trans, to see if fluid would run out [ it should not ]
Old 05-24-2007, 01:31 PM
JJ350's Avatar
It's a th350. I haven't pulled the line off yet, I just haven't had to chance. I havent' even checked the trans fluid level yet. I was just assuming it was overfilled becuase of the oil being discolored. I'll do this tonight. thanks
Old 05-24-2007, 01:45 PM
JJ350's Avatar
I suppose it could also be a bad modulator which would leak and get pulled into the engine via vacuum hose.. right?
Old 05-24-2007, 01:56 PM
what happens
The act of overfilling your trans would not cause the modulator to go bad.
Check the hose, check your fluid level.
If it is overfull, and the fluid looks nasty, but the trans works good, drain out as much as you can.
Take a good look in the pan, hopefuly you won't see much debris.
If that is the case, well just getting the nasty fluid out will go a long way to insuring that the trans will stay working good. Good luck!
Old 05-27-2007, 02:22 PM
Haulin327's Avatar
I dont know the answer to that ?, but what I like to do on a good tranny service is to rig a 2.5 gal gas can full of atf under and connected to pickup with hose(with pan removed) and suck the can dry.
This can make a big mess so put the gas contaner inside a larger(kitty litter) plastic tub.....
This will flush clean atf thruout trans/convertor....
Drilling and tapping a drain hole"aka MB" in convertor also a idea...
Old 05-27-2007, 03:38 PM
powerrodsmike's Avatar
Wiki Edits: 161
A faulty modulator will allow oil to get sucked through it, a good one will not.
I always heard that when you overfill a trans or motor the rotating parts whip air into the fluid that is in the pan. The idea is that the proper fluid level should be a fair distance below these rotating parts. When you overfill it, the level is so high that it touches those rotating parts.
Air does not lubricate, so the little bit of oil that is present in that frothy fluid gets overworked , burnt and starts to allow metal to metal contact.
Also, oil expands when it gets hot, and overfilling can lead to pushing the excess out the vent.
I can't say that I know all that is the absolute truth, , it's just what my pappy tol' me.
Later, mikey
BE different....ACT normal.
Old 05-27-2007, 04:06 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Does it smell burnt?
It ought to Ive seen the "strawberry milk shake" water & trans mixed but chocolate milk
YUK
sounds like you need to find a shop that can do a blood transfusion the have a machine that does this I think its a motor vac brand.
Have them pull the pan & look for ground up metal parts.
Most likely your trans is living on borrowed time
R
"SlowRide66"
"Illegitimis non carborundum"
Old 05-29-2007, 11:25 AM
JJ350's Avatar
Just to elaborate the chocolate milk look I was referring to ins't the trans fluid, it was the engine oil, thats why I was thinking the modulator is faulty and is allowing the fluid to get sucked into the intake and down into the cylinders. Thanks to everyones responses, I still havent' had the time to remove the vac. line to see if trans. fluid is coming out.. i've been very busy...
Old 05-30-2007, 08:42 AM
Frisco's Avatar
Glad To Be Here
Engine oil that has the appearance of "Chocolate milk" is usually the result of water in the oil.
Some possible causes are:
Intake manifold gasket installed incorrectly.
Blown head gasket.
Cracked head.
Cracked block.
If the modulator valve was broken internally and allowing trans fluid to be sucked back to the intake manifold at the vacuum connection, this oil would go out the exhaust and would /should cause excessive exhaust smoke. It would not enter the engine oil to mix with it.
Old 05-30-2007, 10:30 AM
JJ350's Avatar
How about the tarp that I have covering my truck has a hole in it There was standing water from the rain on my intake, and it was all the way up past the dizzy gasket.... I have a hole in my hood to run a scoop that I don't have yet... I tape some plastic over it , hopefully that will do it.. thanks everybody.
Car-toons I mean tunes! kringold Hotrodders' Lounge 107 10-20-2006 09:10 PM
Jegs 350t trans..... No good!!!!!! tiresmoke55 Transmission - Rearend 15 08-12-2006 12:24 AM
New Trans and Driveshaft - Truck moves when in park Z-Money Pit Transmission - Rearend 2 01-28-2006 09:04 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 09:51 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 02:23 PM
