Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What happens if you overfill your trans?
Old 05-30-2007, 07:42 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Originally Posted by JJ350
Just to elaborate the chocolate milk look I was referring to ins't the trans fluid, it was the engine oil,
Engine oil that has the appearance of "Chocolate milk" is usually the result of water in the oil.
Some possible causes are:
Intake manifold gasket installed incorrectly.
Blown head gasket.
Cracked head.
Cracked block.
If the modulator valve was broken internally and allowing trans fluid to be sucked back to the intake manifold at the vacuum connection, this oil would go out the exhaust and would /should cause excessive exhaust smoke. It would not enter the engine oil to mix with it.
