what happens without a canister - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2005, 12:36 PM
What happens when 2 of the 4 vacuum lines are disconected on the charcoal canister ?
Old 11-17-2005, 12:38 PM
larryblack's Avatar
Certified Lead Foot
You get a vacuum leak unless the hoses and fittings on the canister are plugged.
Old 11-20-2005, 12:03 PM
Tazz
I don't understand??
Why would you disconnect the lines from the dump canister? At least plug the hoses, Now the canister lines must be capped off too. This canister just captures the fumes, gas and oil vapors and lets them condense inside away from the carb, or throttle body.
Tazz
Need help on how to hook up the vapor canister Streetmaster Engine 2 09-02-2005 07:59 AM
Removing charcole canister stinky jinx General Rodding Tech 9 04-22-2005 02:13 PM
Charcoal Canister Question Jag Daddy Engine 0 04-16-2004 04:53 PM
Charcoal Canister BT74 Engine 3 12-16-2003 07:00 AM
Help! How do I install a new power steering canister to my existing pump? boricua_stang Suspension - Brakes - Steering 1 10-02-2003 06:48 PM
