what have I done??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2002, 02:21 PM
Question what have I done???
I was under the hood checking and tightening things as needed..stood back to listen to it purr..when like a ******* I decided to rev it up..possibly a bit too high...after it settled back down to idle it began idleing really rough and wanted to stall....checked timing, vacuum, oil pressure..everything is normal...and now when you pull a vacuum line off the idle increase a lot..could I have floated a valve or valves??? ot maybe blown out the power valve in the Holley???the engine is a 68 302...all new internals..milde cam..holley 600 cfm duraspark ignition...any help will be appreciated...
Old 08-25-2002, 04:57 PM
MI2600's Avatar
Member# 3287
Post
Pull the plugs and see if any one cylinder is having problems.
Old 08-25-2002, 07:48 PM
aka Duke of URL
Arrow
[quote]...and now when you pull a vacuum line off the idle increase a lot..<hr></blockquote>
Does the idle seem to stabilize when you open a vacuum source?
Maybe something was drawn through the fuel line and has upset the needle and seat. Have you checked static fuel pressure? Maybe a surge such as you produced caused the fuel pressure to jump and forced the needle off the seat when the bowel was full resulting in a flooding condition. Do you have the proper power valve in the carb?
Old 08-26-2002, 01:56 PM
Post
yes the idle smoothed out pretty good....pulled all plugs and each one was black with carbon....wheras 2 weeks ago they were a nice sandy color...after checking to make sure all valves were seated I began checking the carb...we have had trouble with the primary float level from the time we got it....readjusted the float....tapped on the front bowl with a hammer handle....then started it up and now it seems fine..readjust the carb mixture using vacuum gauge...checked timeing..on the money...now it is running fine.. now when you pull a vacuum line it tries to stall...thanks for your help....
[ August 26, 2002: Message edited by: 5.0 Fury ]</p>
