What head gasket for my SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2008, 04:06 AM
v8hed's Avatar
AK427
Was running what looks like a stock ~0.039" compressed gasket. However, that would mean a ~0.064" quench area. Thinking of installing Felpro 0.015" gaskets on re-assembly to get a 0.040" quench area. However, my current CR is 9.38:1, so the Felpros would push that up to ~9.9:1 with my iron heads.
What do you guys think? Stick with stock gaskets, or go for the 0.015" items? What would that gain me in performance?
Thanks,
Ian.
Old 06-16-2008, 04:55 AM
SSedan64's Avatar
Thanks,
Ian.
With iron heads the the coated .015 gaskets will work. The .040 quench will also help guard against detonation so the extra compression will not be as bad. You may need to up the octane a little and adjust ignition timing. What heads are you using? Not sure how much performance will increase.
Old 06-16-2008, 05:18 AM
v8hed's Avatar
AK427
Originally Posted by F-BIRD'88
Use cooler heat range non projected tip spark plugs.
I was going to use NGK BP5FS. Is that too hot?
honda 2.0 head gasket jerw55 Engine 9 01-29-2007 09:43 PM
390 FE Blown head gasket: Thinking Man Engine 21 01-23-2007 06:31 PM
Thick head gasket to lower compression? Warrant Engine 16 09-20-2006 07:43 AM
SBO 350, Head Gasket help, with photos 360Camaro Engine 5 07-11-2005 08:29 PM
SBC 400 shim head gasket sb72elcamino350 Engine 4 06-28-2004 07:47 AM
