What To With Head Gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2002, 09:00 AM
Post What To With Head Gaskets
Which head gasket should I use and how should it be installed with waht type of sealer if any. I've got a gasket set from Fel-Pro will the head gasket in the kit be ok. I don't want anything to go wrong.
The motor is a 350 bored .030, flat top pistons vortec heads, alum intake, carb and so on, approximately 330 hp, daily driver.
Old 08-26-2002, 09:58 AM
Biggarmike's Avatar
Chief Procrastinator
Post
Clean and dry, the gasket in your FelPro kit is fine. Torque heads carefully as per spec. re-check after cam break-in and engine has cooled.
Old 08-26-2002, 10:10 AM
Post
Thats what I thought but i've herd of others using spray sealer or even painting gaskets with a copper coating.
Old 08-26-2002, 03:00 PM
4 Jaw Chuck's Avatar
Post
Dry and clean is the best.
— Han Solo
