What Heads?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2004, 09:54 AM
HemmiGremmie's Avatar
Last journal entry: 52 truck
What Heads??
Hello.
Is there any heads out there that dont cost 800 bucks that is decent for performance???
I cant find any aftermarket head thats under 7-800 dollars. B&M used the big valve dbl humps on there test mule engine and got 525 horses on pump gas with there blower. Would I be wasting my time? How bout then Ebay stores that use the 882's and port em and install bigger valves? Im not shootin for the fastest street car shootout or for all out drag race racing.
Im buying my rebuild from PAW next week, so need to get thinking. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 10-08-2004, 09:55 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
You can get a new set of dart cast heads for that price & will do the job.
Luv the smell of NITRO in the morning.
Old 10-08-2004, 11:13 AM
firestone's Avatar
http://teamrfc.gospelcom.net
I would get a set of Vortec heads. You can get a set ready for up to .525 lift for $650 a set, assembeled. If you are using a cam at or under .500 lift, the vortec heads will out perform the dart,WP... of the same size, and they are cheaper. Personally, I think going with the other stock heads is not an efficient way of spending your money. You will have alot of money in them if you want to get the performance that you would have with the vortecs.
Adam
Here is a site to buy the modified Vortecs (able to handle .525 lift)
http://www.sdpc2000.com/cart.asp?act...=2172&pid=9063
Old 10-08-2004, 04:01 PM
I like the Vortecs, but I cant use em with a roots blower.
Which heads are you talin about George?? HG
