What heads do I have? They have two Pyramids on them? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2002, 04:25 AM
Post What heads do I have? They have two Pyramids on them?
Mine apparently are not "Camel Heads" but instead, have two PYRAMIDS in place of the camel humps.
This is the info that I pulled off my heads..
GM "1"
399897
A-2-73
"T"
CONV-4
I have no idea what this means... the heads are currently on a 1974 350 4-bolt from an Impala Police Car. I found that whole set-up from a 1976 Camaro that I ended up junking (body was way too badly rusted) and now it sits in my garage waiting to be dropped into an 81 TransAm.
Any idea what I have?
Todd
Old 07-31-2002, 05:52 PM
MI2600's Avatar
Member# 3287
Post
The closest I could find was casting # 3998997 which is listed to a '72 400 engine with 1.94 & 1.5 valves. Do these heads have steam holes? Do they have bolt holes in the ends? If so, they're probably 76cc open chambers.
Old 07-31-2002, 06:00 PM
MI2600's Avatar
Member# 3287
Post
I forgot to add that the double "pyramid", at least by my meager references, came on castings #415, #545, and #493, which came on 267, 350, and 400 engines, respectively. I don't know what symbol the #997 had. Maybe someone else can shed some light on this.
Old 07-31-2002, 07:33 PM
E.T. divided by $ spent= Speed
Post
I think the old "power pack" heads had a block w/ a pyramid on it(were the double humps would be).Google search the last three #s Ex."GM #897 heads".I've found tons of info when I search for some heads I had.
Personally I would say if they got 1.94+ valve and no accesory holes there probably desent flowing heads cause their pre smog.
Old 08-01-2002, 06:42 AM
Mrfixmaster's Avatar
Last journal entry: Red, my second T--Bucket
Cool
Try WWW.Mortec.com for the casting number list. They have lists for heads, blocks, and trannys.
