what heads to use??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2010, 02:48 PM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
ok so i have got a set of heads with numbers 6272292, with my research says they came on early 70's 402. and i have a set of 346236, from what i read these are the peanut port heads. both are open chamber. ok so now for my question, i am building a budget 454 and i have these 2 heads on my garage floor to chose from and only have the money to have one set rebuild. with one would be better? i am not looking to go to radical with this build. my goal is only about 450hp with over 500tq. any help would be greatly appreciated.
Old 05-31-2010, 04:41 PM
BOBCRMAN@aol.com's Avatar
Really not much of a choice. The early heads have 122+ cc. chambers. Small valves, not un-lead gas compatible and terrible flowing intake runners.
Only thing better on the later heads are the combustion chambers are smaller.
IF you do the early heads correctly. New exhaust seats, guides valves etc. ...Install hard seats for the exhaust. I usually do the 1.88 route on the exhaust. But these heads will only go stock (1.72) exhaust size. The seats larger will break thru the casting.
Then install 2.19 intake valves in heads. This will require a competant shop and a lot of hand bowl grinding. Cut the head surface .030 and you are at about the best you can get from these heads. NOT CHEAP and you can probably find better stuff for less.
Trade the peanut ports to the shop for door stops (thats what I use). Or weight. Possibly someone with a med-duty truck might need them to replace a cracked one..
Old 05-31-2010, 04:52 PM
chevykid90's Avatar
ok so your saying use the 402 heads? thats kinda what i was thinking about doing from what i have read about them online. the guy who is going to do my head work said that he would take 50 bucks off the price if i gave him my peanut heads.
Old 05-31-2010, 05:53 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
who is doing the heads?
just currious
Old 05-31-2010, 06:18 PM
chevykid90's Avatar
i found a guy on craigslist who was selling some heads and in his add he stated that he also did head work. i am just wondering which head would be more beneficial to put on my motor.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
milling heads Raufus Engine 12 02-22-2010 02:41 PM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
Heads and Intake combo black66 Engine 4 07-23-2005 11:33 PM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 01:16 PM
