What heads to use on a 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2010, 11:08 PM
i'm building a 4 bolt main 350 for my nova and wanna push around 400hp would like to no a good set of heads to start with. if u wanna take it one step further and include specs for a good cam ie. lift / duration that would be very helpful.
Old 09-25-2010, 03:58 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Here is a list of over 100 small block builds that were dyno'd. Choose one that you like....
http://www.ryanscarpage.50megs.com/combos1.html
Old 09-25-2010, 08:28 PM
There are several choices for aluminum heads, but GM Vortec iron heads are usually one of the less expensive choices. If you take a look at combos 73, 78, 89, 99, 108, and 109, they all use Vortec heads and make decent HP. The last three of these combos exceed 400 HP, which seems to be what you want.
I'd also plan to use a hydraulic roller cam if possible, since you will need a fairly aggressive cam to get into the 400 HP range.
Bruce
305 heads with 1.94 valves on a semi stock 350? robbiesmechanic Engine 4 03-20-2009 09:19 PM
350 chevy heads question pena0724 Engine 7 03-02-2009 06:09 AM
Piston preference for a 350 with 305 heads Old School Baja Engine 0 01-07-2007 07:23 AM
olds #5 head johann Engine 1 07-30-2006 10:05 PM
283 heads on 350 70 nova Engine 5 11-09-2005 08:26 AM
