what heads would be better - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2013, 03:55 PM
Trying to get my project on the road but am confused just gettin in to this..so ive got a 454 cast#(10069286 or 10068286) i cant make out the 5th number the heads it has are cast#14081045 and they have a plaque stating they are remanufactured by GM but i also have some heads off a 396 cast #3909802 I was hoping i culd get some advise on wich ones i shuld use
Old 03-25-2013, 04:49 PM
BOBCRMAN@aol.com's Avatar
What is the intended use and expected horsepower?
Old 03-26-2013, 08:25 PM
Id like to be able to drive it daily if needed..looking for about 450hp
Old 03-26-2013, 09:26 PM
Neither set flows great, just mediocre heads. The 396 heads have smaller chambers (109 cc) this would add compression, but require the large, hard to obtain "N" series plugs and won't last on modern fuel without hard seats.
Big blocks need to breath to make power.
What kind of budget ? What is it going in? Inteded use?
Old 03-26-2013, 11:08 PM
first thank u for the feedbakive got about 1k to spend but i also wanted to get a nice cam for it its going on a 69 chevelle i want it for street/(strip every once in a while...)i have a weiand high rise intake and 800 demon carb already and im going to back it up with a 200r4
Oppinions EQ lightening heads and EQ vortec heads eatonde Engine 16 02-19-2013 12:00 AM
305 heads or 350 heads on sbc 355 ryan v Engine 5 09-20-2012 11:21 AM
swapping 351W heads for 302 heads babell7738 Engine 10 01-21-2012 11:16 AM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 09:34 PM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 05:12 PM
