most all of the monte's i have seen have the 200r4 in them. if you go to b&m racings web site they have a chart that shows the shape of the pan and you can compare it to yours to find out for sure. i think their web is <a href="http://www.bmracing.com." target="_blank">www.bmracing.com.</a> hope this helps..
i think that be right, either a 200 or a 250.
both of which i have heard refered to as "slush box"
the pan should be the same basic shape as a th350, but will say "metric" like yours, or
"hydromatic div. of gm"
most of the GM A bodies in the mid to late 80s used the 200R4 with the V8s and buick used them with the Grand National.These trannys had a lighter first gear than the 700R4 and a .63 overdrive, and most I've seen had dual bolt patterns. a fairly decent tranny
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
