What is this?? Help ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2008, 10:33 AM
It was in a my box of motor parts have no clue what and or were this came from I need help!
It seens to be a ball baring sloped in the the top.
Thanks
Old 11-04-2008, 11:04 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Are you talking about the little hardware on top? Try a better picture. That one is fuzzy. I can't tell if its a pipe plug or an Advil tablet.
Old 11-04-2008, 11:31 AM
racecar100's Avatar
The Black one is Cam Thrust Button and The brass one is Cam degree bushing
Old 11-04-2008, 01:16 PM
"Cam Thrust Button" You got skillz...
Now do I need it?
Old 11-04-2008, 02:58 PM
mrdreex's Avatar
Now do I need it?
Do you have a retrofitted roller cam?
Old 11-04-2008, 06:01 PM
drive it like you stole it
C'mon,,was the blower the only table you had open or u just shown off
Without that button against a retro cam you'll have definate catastrophic failure
That bushing would really help as well,,,,at least w/ timing,,,but believe it or not I've taken a timing chain cover off a motor that had some miles put on it w/o that bushing,,,,,ran like ***** but it ran.
Old 11-04-2008, 07:02 PM
Not a roller cam...Just a mild comp cam with roller rockers.. So that means I don't need it correct? But what holds the cam in then??? Chain there is not plate on this block.
LOL Blower was the only clear placeto take the photo lol
Thanks for the help guys.
Old 11-04-2008, 07:05 PM
mrdreex's Avatar
Wait, not a roller cam, and running roller rockers? Don't think you can have it both ways, as flat tappets have a taper which keep it from sliding out. Roller cams don't have it, thus the need for a cam button.
Old 11-04-2008, 07:18 PM
You can actually have roller ROCKERS with a flat tappet,,,just not roller LIFTERS,,,at least I've never heard of it????
You don't need the cam button.
Old 11-04-2008, 10:39 PM
mrdreex's Avatar
Oops, read that wrong, or atleast misinterpreted.
Disregard my post.
