What holley 750cfm carb to go with ??? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-26-2003, 09:39 AM
CamaroX
The cam is just a 69 302 offroad cam that was purchased when the crate engine was. The specs for the cam are here http://www.holisticpage.com/camaro/parts/cam.htm
last one on the page. Lifters are just the stock solid pieces.
The heads are 426 double humps from a 70 Lt-1. Intake and exhaust valves are slightly larger than stock I have been told.
Im thinkin the 750hp from holley would be a good choice? with the extra info what do ya guys think?
  #17 (permalink)
Old 09-27-2003, 08:14 PM
DoubleVision's Avatar
Honestly, I`ll tell you what I think. I think you got a lot to learn as far as hot rodding goes, you need to invest much much time (a year at the least) into reading books such as "how to hot rod the small block chevrolet" or "Max Chevy Performance" your engine idea is not a very realistic one, I don`t know where you heard the 302 made it`s power over 7500 RPM, if that had been the case from the factory the car would have never been streetable. 302`s are not low end torque engines, and to run a cam that will rev over 7500 RPM and stay together will require a very heavy duty valve train, and I`m talking good stuff, such as valves, springs, guide plates, rocker arms, heat treated push rods, hardened locks and retainers, your not gonna take a stock set of heads and bolt them on and expect to rev it to hell and it stay together, valve train dictates with a iron hand how high a engine will rev, and at that RPM you have to have a bottom end that will take revs that high and hold together, stock rods aren`t gonna cut it. 12:1 compression,, lets see, that says right away it won`t be streetable, unless you plan on running 108 octane race fuel, it`s not gonna run on pump gas from the nearest gas station without detonating itself to death in a very short order, if you don`t believe what detonation can do, the late Smokey Yunick said "detonation has destroyed more engines than I could ever count, if I had a nickel for every engine that blew from detonation i could buy a small country and retire"
462 heads did not come on LT-1`s, there last production year was 1967 and they came exclusively on 327`s.
to run the car with that kind of RPM you must be planning on running 4.88:1 gears, that`s the only way the car will have any low end power, high rev engines have to make up for there lack of torque with low gears.
Not trying to be nasty, but hot rodding is not something you learn over night from old stories on what cars in the 60`s did, technology has advanced a hell of a long way since then, and I think many stories from then get greatly exaggerated over time from one person to the next. I`m only being honest and telling you this because no one should jump into any project with goals like you have and not know how to get there, if you go on to build this engine the way you want it to run your gonna make a lot of junk pieces getting there, you can`t sneak up the horsepower ladder in little stages, either you stay with stuff that can handle the power the engine makes, or you do it right the first time and spend the money needed to make a engine perform this way the first time and you`ll be money ahead, blocks, cranks, rods, and etc get expensive over time after you end up replacing them due to blown engines from trying to sneak up the ladder. Engines either do 2 things, either they make power down low, or up high, there isn`t a engine that will make both, and I`d rather have a engine that makes lots of low end torque than have one that revs to hell. Bob Glidden won all the championships he did from Torque, if you go back and watch and listen to his car running back in the day, the exhaust note is clearly different from all the rest, he didn`t have to rev it to death to win. torque is what you feel, it`s what pushes you back in the seat, it`s what moves all that sheetmetal around, not horsepower. engines that make power in the low RPM band last a lot longer, high revvers wear parts out quickly from continued high RPM flights. so there you have it, that`s pretty much the basic start on how things work, read up and learn more, then build your project, you`ll be happier you did and so will your wallet.
  #18 (permalink)
Old 09-29-2003, 03:58 PM
CamaroX
i put wrong number excuse me
3991492. Another good performance head. They were found on 1970 LT-1 engines. They had 2.02/1.60" valves, 64CC combustion chambers, DO have accessory holes, intake port volume should be 161CC's, exhaust port volume should be 62CC's. These heads have double hump casting marks. This particular casting head was also available as an "over the counter" head from GM in straight or angle plug configurations.
it would be those. 2nd off its a gm over the counter cam, nothing special. Im not trying to make it any better than it already was in the early 70's.
I know I have tons to learn thats why im not trying to mix and match stuff now. Im goin with a something that has already worked b4, and all i wanted to know was what carb to go with. and i was a bit off on the rpm, 290hp claimed at 5800rpm
thx for the advice though ,i will pick up one of those books
