If this is a daily driver a 750 #3310 vacuum secondaries, for race & play a 750 HP it the ticket.
Luv the smell of NITRO in the morning. |
Id use a HP 750 instead of the dominator..I use part # 80528-1
Why not rebuild the old 750???Was it a double pumper??
Pretty much what ever you buy will need to be taylored to your motor anyway,so I would just(unless its shot)rebuild the existing carb using propperly matched power valves,then jet it and play with ecelerator pump cams. If you do buy one I'd say just a 750 double pumper.I think the factory Z28s came with a 780 DP. |
I agree with 78 monte rebuild it, not hard to do if you follow the instructions.
Holly Rebuild and Adjustment Instructions http://www.holley.com/HiOctn/TechSer.../Instruct.html If you need any help while rebuilding please post the question. George
Go get a proform main body and clean and rebuild the 750 that you have, you will be out only around $120 or so for the main body and gaskets and will have a fresh carb that runs great. I have one on my 383 and love it.
l8r -j-rOd |
If I were you I would go with the DEMON carb more smoother and better performance than the Holley would ever think of being. And unless you have over 400 hp I would go with their 650 size carburetor. TO many people think they need a 750 when they do not, plus there 650 is larger than the holley 650. Do not use the 750 Dominator not worth having on the street.
You could go with either a 650 or 750 Mighty Demon on your combination (Both less expensive than an HP).
A 650 Would probably give you better acceleration, and drivability especially with the large exhaust system. The 750 would pull harder if you turn the engine over 7500 RPM |
its gonna have to pull over 7500rpm
since thats where its power is made. My dad has had plenty of carbs on it from old 450cfm 2 barrels to a 800 something 750 seemed to be the best so we are gonna stick with that. Even if the carb has been sitting for like 18 years and even when it was put away had a ton of miles If i were to rebuild it would it still be as good as new? And how do I clean this thing off? Its mighty dirty![]() well then my dad forgot to mention he didnt know what the carb was, and as it turns out its just a 585 so then i need new one i guess!
[QUOTE]Originally posted by FiefSS
[B]its gonna have to pull over 7500rpm since thats where its power is made. Intake classic edelbrock tarantula a winner for a 302. Can you Please tell me what cam you have? With a stock bottom end, and AT OVER 7500, double hump heads trimmed so compression is around 12-1 to 12.5-1. This is one great motor, how much HP do you think it will make?
I`m in agreements with 1BAD80, not enough info here. Although, I could say much more, I`m not gonna, I would rather wait to see how this turns out. another one tryin to sneak up the horsepower ladder. best of luck,,, your gonna need it.
![]() Allthough they do make good wheel chucks in a pinch. |
