what how to rebuild my 350 for about 350-400hp - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2006, 09:58 AM
can anyone let me know what engine kit, where to get itfrom(part #, stores) i need to rebuild me engine or probly just new heads/valves/the upper end. now it is pretty stock i believe. it does have a rv cam in it. i want 350+ hp. can i do it with no rebuild?????????
Old 01-16-2006, 10:54 AM
poncho62's Avatar
Wiki Edits: 5
moving to engine forum.
Old 01-16-2006, 11:03 AM
Bugs's Avatar
Bugs
I guess you could bolt on enough stuff to get that kind of HP if you wanted to but what 's the sence of doing all that if you have a worn out bottom end?While your into that far you might as well freshen up the short block too, IMHO, good luck
Old 01-16-2006, 11:13 AM
firestone's Avatar
http://teamrfc.gospelcom.net
This will do it.
http://www.sdpc2000.com/catalog/2172...former-RPM.htm
Adam
Old 01-16-2006, 11:46 AM
same kit basically what i am going to run. it will do it for the least amount of money. DON"T FORGET HEADERS!!!
Old 01-16-2006, 12:35 PM
firestone's Avatar
Forgot to mention, you will need new valve covers also. You can find them for around $50 a set.
Adam
Old 01-17-2006, 10:28 AM
AFR heads, a bigger cam, RPM intake, 750 holley carb, and a set of headers will get you 400hp. Keep the small rv cam and get 370.
350 rebuild (heads) rpainter87 Engine 13 05-06-2003 01:29 PM
350 rebuild MHenricks Engine 2 07-18-2002 08:12 PM
350 rebuild hot57 Engine 5 04-08-2002 08:25 PM
Change of Plans for 350 rebuild ! 56wagon Engine 14 03-26-2002 05:44 AM
350 rebuild ideas pls 56wagon Engine 6 03-04-2002 08:41 AM
