what is it ? ID this Chevy posi deferential - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2013, 01:41 PM
Blown 23 T's Avatar
I'd Rather Be Blown
Last journal entry: Paint remover
I have a 67 Camaro. i am doing a full restoration (see my photos) anyway i am now to driving stage and the posi is not posi-ying or how ever you say that.
i know its posi because when jacked up in neutral the tires spin the same way. When in 1st gear they spin opposite direction with very little effort.
So i pulled the cover to see what I could see. The only stamped numbers that I can find are on the ring (137-11GM 668 A N) the 1 is kinda faint. Ring is 37 pinion is 11 so 3.36 to 1... i am OK with that.. what type of posi do i have.... I have wiped it all clean and all i can find is a faint cast number on the back side of the ring plate (it looks kinda like( 10) maybe (18) then a blemish after the 0.. or 8?? nothing defined. I can't find anything else .
the diff housing has the letter N on top of the pinion. no stamped numbers.
my understanding is that it is a 7.5 of 7.65 " ring gear from the small **** on the bottom of the pumpkin. any way to tell with out pulling it.
I am hoping to get the rebuild kit before i pull it. to limit down time.
Can anyone tell me what i have .
Is it a posi or a limited slip???? is nit worth saving or am i better to just up grade????? and is it OK to run as a driver maybe a once or twice on the track for fun? (M22) 4 speed, 245-60X15 rear...
I have been on Google for hours and could not find a picture of it???
Thank you
Name:	posi gears small.jpg
ID:	74146   Click image for larger version
Name:	outside small.jpg
Old 05-19-2013, 02:04 PM
BOBCRMAN@aol.com's Avatar
" When in 1st gear they spin opposite direction with very little effort."
Not a posi.
Old 05-19-2013, 04:05 PM
I believe that is a 4 pinion cone clutch diff. If the wheels spin different directions when in gear it is a very worn out posi and not really rebuildable with normal methods.
Old 05-19-2013, 04:12 PM
big gear head's Avatar
High Performance Rear Ends
Someone has put a first gen Firebird rear end in your Camaro. That is the 8.2 BOP 10 bolt, not the Chevy 10 bolt. These are about 1 inch wider than the Camaro rear end. The differential is the Borg Warner cone type limited slip (posi) differential with 4 pinion gears. This can be reconditioned, but probably only one time. There is a place in Ohio that reconditions them called Pontiac Posi Rebuilders. Their number is 330 799 4619. You can not get a rebuild kit for the differential, but you can get a rebuild kit for the rear end. The axles are bolted in and do not have c clips.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
Blown 23 T (05-19-2013), Crosley (05-19-2013)
Old 05-20-2013, 12:53 PM
Freddie;
Man you should write a book
Old 05-20-2013, 04:13 PM
Originally Posted by AutoGear View Post
Freddie;
I actually started one several years ago but gave up because I didn't know how to do it. I know what I wanted to put in it, but I didn't know how to put it all together. At that time there were no books available on rear end, but now there are at least 3.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (05-20-2013)
chevy, differential, posi, rear end
8.2 63 Chevy rear posi cowbay Transmission - Rearend 6 06-14-2008 03:54 AM
1970 10 bolt Chevy posi sanman Transmission - Rearend 6 03-05-2008 09:57 PM
Broken posi POS chevy 66 T-Bird Transmission - Rearend 8 01-30-2006 06:33 PM
'77 Chevy 8.5 posi Greg47 Transmission - Rearend 0 03-16-2003 05:36 PM
89 chevy p.u. posi catdad2u Transmission - Rearend 3 11-09-2002 03:23 PM
