What is the ideal gun nozzle sixe for shooting primer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2011, 02:03 PM
Marty7n's Avatar
Last journal entry: Lancer face lift
I have a 2.2 gun and 1.4 i have a 2k primer!
which would be best 2.2?
or 1.4?
both are H.V.L.P guns
Old 04-17-2011, 02:11 PM
2.2 for primer
1.4 for paint
Old 04-17-2011, 03:22 PM
Read the tech sheets!!
But 2.2 seems a little large for urethane 2k, does it not? I'm not paint master, but...
Old 04-17-2011, 03:28 PM
Underground's Avatar
Last journal entry: 54
yes a 2.2 is too big for 2k. You shouldn't need anything bigger than a 1.8(preferably a 1.6). A 2.2 is for polyester primer.
Old 04-17-2011, 03:54 PM
i use a 2.0 for primer, and 2.5 for poly.
every primer is different...i've shot primers that will come out of a 1.6 just fine.......and some that need a 2.0.....talking 2k here, not poly.
for that matter every poly is different. slicksand will spray through a 2.0 just fine......but sikkens wont......needs the 2.5
can always adjust that 2.0 down.
Old 04-18-2011, 01:48 PM
Marty7n's Avatar
Its a 2K max meyer primer + hardener,it says on tech sheet 1.6 - 1.8 like!but i dont know if the 2.2 will adjust out for it!
Old 04-18-2011, 05:03 PM
put up or shut up
2.2 is way too big for 2k. You will blow thru it too quickly and likely have a run, which is rare in primer. A 2.2 is even big for featherfill and is really only good for slicksand. 1.6-1.8 is ideal.
Old 04-18-2011, 06:27 PM
Old Fool's Avatar
just close the fluid needle a bit, it'll work fine
1.4 spray nozzle primer Marty7n Body - Exterior 4 04-11-2011 05:46 PM
Shooting color after primer DBEEG Body - Exterior 1 09-10-2009 10:49 AM
Is a 1.3 tip ok for shooting epoxy primer? AntnyL Body - Exterior 12 08-10-2009 01:20 PM
shooting primer Wraith Body - Exterior 2 07-23-2009 03:43 PM
will any gun do for shooting primer? Dubz Body - Exterior 3 04-27-2004 05:48 PM
