What if I set up a carb on my rebuild... - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2003, 07:39 PM
CamMan's Avatar
What would I need to do in order to setup a carb on my 350 rebuild? I will be getting the block back soon and I am going to start the rebuild sometime in Jan. I have a set of 461 heads now and I am probably going to go with a carb setup. Will this be difficult in my 91 camaro rs. It is the one with the 305 tbi in it. Can i just get rid of the tbi and use carb? Can you guys tell me in a as much detail as you can what I will need to do to make this happen?
If you want to take a look at my other posts feel free. It might give you a better idea of what I am trying to do.
Thanks again to everyone here. You guys are a big help to me.
Old 12-20-2003, 07:55 PM
DoubleVision's Avatar
You`ll have to have a intake that has a carb pattern on it. you`ll also need a later HEI distributor with vacuum and mechanical advance, the distributor your now running is useless without the computer, and if you go with a carb the connections for the throttle position sensor will be flapping in the breeze and the computer won`t function correctly so running without the computer is the next step. the 461 heads have no accessory holes, so you`ll have to work your way around this obstacle as well.
