What if my Pinion is higher the my trans out put shaft? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2006, 01:20 PM
Last journal entry: Albany Oregon Show
The output of my trans shaft is 1" lower than my pinion shaft. Side to side I am exactly parallel so I don't have the 3 d thing going on. Most of the time my driveline geometry has been the opposite. How is this going to effect how I will set my four link and pinion angle? Do I still add the two angles together and adjust my pinion to make 180?
Bob
Old 09-11-2006, 02:01 PM
Jmark's Avatar
There are lots of good articles on the web, here is one from Dana.
http://www.streetrodderweb.com/tech/...e_shaft_angles
http://www.iedls.com/guide.html
You can do a search on Google.com on "driveline setup angles" or any like combination and get hundreds of hits.
Mark
Old 09-11-2006, 02:02 PM
Wiki Edits: 49
As far as I know the actual position of the pinion shaft in relation to the trans output shaft won't have any effect on your pinion angles. They should be the same whether the pinion is slightly above or below your trans output shaft.
Fine metal in trans bigjoedo Transmission - Rearend 21 07-27-2003 11:50 PM
How hard to put in manuel trans mr.chevelle Engine 8 07-22-2003 12:27 AM
Easiest way to put headers on a 77 Trans Am. Hot Rod/SS Engine 2 03-18-2003 12:07 PM
T-350 Long vs short shaft change zachscc Transmission - Rearend 2 01-21-2003 01:53 PM
is my drive shaft too short? crebo Transmission - Rearend 2 08-19-2002 02:39 PM
