What if my spark plug look like this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2007, 09:41 PM
Mertz's Avatar
I just got my truck out for a test drive after putting in the roller tip rockers and adjusting the carb. It ran fine but seemed like it had an occational rattle at slow speed under load so I backed off the timing 3 degrees. I was at 16 initall. I pulled 2 plugs to see how I was doing in the richness department since it seem to use a lot of gas on my 50 mile run. One side of the plug was tan and the other side was black. I checked 2 plugs and they were the same. I cut the tips of the plugs so that they were in line with the center of the electrod before I started all the upgrades and it has not been a problem. This is probably why people index their plugs. Seem like it is burning better on one side than the other. Any suggestions for getting a cleaner burn?
Old 03-26-2007, 02:29 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Chamber shape and fuel distribution.
Ignition system info................ poncho62 Electrical 18 10-11-2008 11:10 PM
Spark Plug brands question Francis Engine 65 07-15-2008 01:01 AM
recomended spark plug.. screamin340 Hotrodding Basics 2 11-18-2005 08:17 AM
Spark arcing outside the plug?? 85MonteSS Electrical 16 11-16-2004 11:02 PM
Weird spark plug situation?? Jim Weeks Engine 4 05-13-2002 08:32 PM
