What if what if? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2006, 01:46 PM
What if what if?
so what if i put cleveland heads on my 302 im building? can i call it a boss. or just a 302 with cleavland heads? and what intake manifold would i need? a cleveland as well?
Old 08-28-2006, 02:19 PM
Last journal entry: Lessons learned, how to's, etc...
IIRC its a custom intake. I had a chance at one of them about ten years ago when they were somewhat popular. They wanted $500 for the intake, heads, and exhaust manifolds. Probably a bargain, but I went with a supercharger instead.
Old 08-28-2006, 03:19 PM
so i can get them off of weiand or edelbrock? what if i wanted say a supercharger what would i use then?
Old 08-28-2006, 04:04 PM
I don't remember who made the intake.
The supercharger I went with was the B&M 144, now made by Weiand, they now make a 177 too I believe for the SBF. I used mine on a Fox-bodied Mustang GT (older carb version). The biggest pain was, and remains to be, the tensioner pully. When I bought the kit it called for the spring type to be removed (bracket actually cut off the alternater bracket) and a screw-type tensioner off of an early 80's Granada?? (I think) installed. I also had to extend the thermostat housing upward. This was all due to the placement of the distributer on the 302, that is, in the way of where the drive would normally go on say, an SBC.
Old 08-28-2006, 04:48 PM
interesting, with the 302 already a high rev engine and putting the cleveland heads and a turbo seems like it would be pretty mean but it also sounds like a crap load of revolutions, what about overheating and would it mess with the engine in any other way?
Old 08-28-2006, 05:09 PM
I didn't see anyone answer the other part of Your question, no it would not be a Boss. It would be a 302 with Cleveland heads. I believe Ford Racing offers an intake manifold for that setup. I think their website describes everything needed to swap the heads, there are some coolant passage holes that need to be modified to put them on. I think it's "Ford Racing online catalog". I had the paper catalog and they had all the details in that.
Old 08-28-2006, 07:57 PM
thanks! for the info on where to get the intake manifold. so what made a boss a "boss" what heads, was it like a sportsman 302 maybe? what gave boss its name? what made the 351 and 427 a "boss" for that matter?
Old 08-28-2006, 08:26 PM
All the Boss engines had screw in freeze plugs and four bolt main caps, I looked up the Ford Racing catalog today, and it is now in a pdf file. Towards the end of the file on the pages (not sure actual page numbers) between 220 and 227 there is a good description of most popular Ford engines. Their website is [URL=http://www.fordracingparts.com]
Old 08-28-2006, 08:45 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
They are called clevor motors. Do a surch on this board and you will find all the information you will need.You will need special pistons,intake, and exhaust for it to work.
Old 08-28-2006, 09:06 PM
wow! so its a lot more than just bolting on some heads and an intake! i wonder if its worth the effort, or how much more performance im gonna get. at least itll be
diff.
dbdbb thanks for the link! i didnt know ford made any four bolts at all. interesting how many ways you can go with the 302. i wonder if you can do windsor heads or maybe even modified heads. as long as their all the same four inch bore right?
Old 08-29-2006, 02:06 PM
btw, besides adjusting my carb, any easy ways to get my engine running leaner?
