What Intake Should I Use - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2006, 01:21 PM
mac350's Avatar
http://www.eastcoastfbody.com/
OK fellas this is the situation. i have a 350 vortec crate . i have on it a gm high rise intake on it know. i swapped the heads for a set of aluminum vortec fast burn's. i have a Vic Jr sitting in my garage. would it be wise to put it on in place of the high rise. will it hurt me or help me.
Old 07-01-2006, 01:27 PM
DoubleVision's Avatar
It`s recommeded you only use a vortec style intake that has the unique 8 bolt vortec pattern. If you attempt to drill the heads to the old style 12 bolt pattern the intake ports won`t line up real well.
Old 07-01-2006, 01:37 PM
mac350's Avatar
the both intakes that i have are for vortec heads.
but ( so you know ) the fast burn heads have prevision's for both style intakes. i found that out when i got them.
but the Vic Jr i have is for vortec heads. i got it because i was going to have my original steel heads ported out and i thought i would get away with it. now Worth the fast burn heasd they have bigger valves and 3 angle valve job so they flow better so i wa hoping i could use it.
Old 07-03-2006, 04:23 PM
mac350's Avatar
hey guys i know you all have answer for me. i get the feeling that the Vic will be to much for me but i am getting inpatient with the coater i am using. pleas help. i want to get this intake on this week!!!
Old 07-03-2006, 06:29 PM
Old Yeller 1970's Avatar
Loud Pipes Save Lives
Your choice of intake really depends on how you plan to drive. I assume the GM intake is a dual plane and if you intend to drive mainly on the street it's probably the better choice. On the other hand if you plan on drag racing and the engine is mainly going to see high RPM's then I'd go with the Victor jr since it's a single plane.
Old 07-04-2006, 10:12 AM
firestone's Avatar
http://teamrfc.gospelcom.net
What are/is your:
stall speed
cam specs
vehicle weight
compression
Adam
Old 07-04-2006, 10:25 AM
mac350's Avatar
2800 stall
lt4 hot cam with 525 lift
3500lb
9.6to1
Old 07-04-2006, 11:15 AM
firestone's Avatar
I would use the dual plane. It matches all of your parts much better than the victor jr. You would gain a few hp on the top end wtih the victor, but loose some low end power. As you see in the article below, switching bewteen the two, the single plane intake only makes more power from 5000-5600 RPM. On the street, you will probably want that extra low end grunt to get the car moving.
http://www.chevyhiperformance.com/te...838/index.html
Adam
Old 07-04-2006, 11:29 AM
mac350's Avatar
thanks for all your help
Can intake side of heads be milled? brainsboy Engine 1 10-26-2005 04:31 PM
Heads and Intake combo black66 Engine 4 07-24-2005 12:33 AM
Theory: Intake volume vs cylinder volume / engine vacuum 59vette Engine 6 04-29-2004 01:03 PM
"Dry" Intake Manifold Question bluesman123 Engine 4 02-11-2004 01:12 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
