What is involved in rebuilding rods?
The title says it all, how do you rebuild them? What is involved here?
connecting rods?
connecting rod bottom ends can stretch and distort at high loads and rpm's. If there is too much crankshaft end play the surface can be rounded instead of flat in that direction. the rebuild process is to machine the flat connecting surface, then bolt the pieces together and torque. that then makes the hole a modified oval, then machine the hole round to the correct size. the piston end on some rods have a bushing that can be replaced then machined to size, , also the rod can be twisted, and requires straightening, this machine work can shorten the center to center length which cannot be corrected. removing material can effect balance so that is the next step in a performance engine.
ive found, that often by the time you pay to have all that done, unless you have some really special con. rods, its not much more to just go buy new ones
what he said do you mean "re-sizing" them for say, ARP bolts?. i have discovered that rather than using arp bolt$ and paying more big bucks to re-size the rods (required), that it is waaaaaay better to just buy new stock rod bolts, and use them, then you dont have to resize the rods. you would be , i think, better off buying cheap new rods than going the arp route, right BobCRman?????? hey dude!!!
So if they machine metal off the rod to restore a flat surface and make the lower rod journal round...doesn't that make an already used rod even weaker?
Good point about throwing the engine balance off...sounds like buying new rods is the way to go! |
because my math includes hanging pistons. so if you buy new rods, you can get floating pin and assemble them yourself i would rather spend my money on new upgraded parts, then pay someone else to do a bunch of labor on older stressed out stuff (but this only applies to, original low perf., parts) |
Yes, my 427 has pressed pins. I guess they're good enough for me, as it dynos at around 465hp, and it's been 10 yrs. of fun since I rebuilt it. I suppose it may go any day now.
not like i need to verify anything you have to say bob, but my machinist said the same thing as you. in jim hands book he said you wouldnt have to. but regardless, you need to check them and most of the time, as i understand it now, you will have to resize them anyway, even with a stock bolt. |
| SBC 4" stroke. What's involved? | curtis73 | Engine | 6 | 03-25-2008 10:50 AM |
| Read this:Your safety is involved | home brew | Hotrodders' Lounge | 16 | 09-21-2006 02:07 PM |
| Longtime car enthusiast getting more involved. | signbuilder | Introduce Yourself | 2 | 01-13-2006 08:01 PM |
| Rearend, whats involved in the swap? | 40chevy | Transmission - Rearend | 6 | 11-16-2005 06:01 PM |
| What is involved in Changing Camshafts? | rick458 | Engine | 12 | 01-27-2005 07:56 PM |
