what ive done to my 327 eng - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2002, 08:15 PM
Cool what ive done to my 327 eng
hi.i have a 65 impala with a 327.when i souped it up i really didnt know what i was doing so a freing helped me.i want to know if what i have on it is right are is there things better??? it has a 650cc holly carb.dynomax headers and differnt manifold.its a little higher than the org.it runs great.and i dont know if it has a bigger cam are not.sounds like it thought.these eng just doesnt quit.also is there anything simple for more power?? <img src="graemlins/pimp.gif" border="0" alt="[pimp]" />
Old 12-16-2002, 11:14 PM
abe abe is offline
Post
yes add a set of headers to help get the exhaust out faster. this should help get at about 10 percent more power.
Old 12-17-2002, 04:21 AM
Wiki Edits: 49
Smile
Looks like you have most of the simple stuff covered. Carb, intake, headers etc. You could invest in a good electronic ignitiion system which will improve reliability, starting and high rpm spark and while you are at it make sure you have good sized 2 1/4" exhaust pipes (dual) running a crossover pipe and low restriction mufflers. Other than this stuff you'll need to start getting inside the motor to add power.
Good luck.
Centerline
<a href="http://www.hotrodsandhemis.com" target="_blank">http://www.hotrodsandhemis.com</A>
