junkyard heads
page 5 of the classifieds, 69-70 dbl. hump heads in good shape "advertised" for $400. these are usually good for 3-400 hp if all else is comparable,
junkyard heads
bt nthe way these heads are in college station
Professional Products sells a couple Eddy knock-offs, p/n 52007 is a Performer knock-off for around $130, IIRC. |
Hi,
I'd go for the vortec's, you can get new iron ones for around $500. you'll need a manifold for the vortec's. rich |
X2 on that. Also consider what kind of engine you're going to build. High compression screamer, forced induction boost monster (chances are not because of your budget idea), low rpm torquer, high rpm screamer, etc. Check out www.summitracing.com |
Do you know what the compression of your current engine is? Vortecs have a 64cc combustion chamber. You want to be carefull not to go too high if you want to stay on pump gas. If you are thinking about buying a set of heads, you can get Vortecs capable of .475 lift out of Jegs for $578. Those heads in a 350 with the comp xe262h (218 224 @.050 .462 .469 lift) and a performer RPM intake should put you around 350 hp with 9.5:1 compression.
Heads: $578 http://www.jegs.com/p/GM+Performance/749896/10002/-1 Cam and lifters: $160 http://www.jegs.com/i/Comp+Cams/249/CL12-238-2/10002/-1 You will also need an intake: $180 http://www.jegs.com/i/Edelbrock/350/7116/10002/-1 And center bolt valve covers:$92 http://www.jegs.com/i/Mr.+Gasket/720/9415/10002/-1 And self aligning rockers:$56 http://www.jegs.com/p/GM+Performance/761650/10002/-1 These are prices out of jegs, but you may be able to save a few bucks on the intake and valve covers if you can find them used. Based on the best I could find, I think it is 8.5:1 compression. If that is the case, the vortec heads would take it to ~9.8:1 which would be great for the vortecs and the cam mentioned. The lowest I found that it could be was ~7.9:1 which would give you 9:1 with the Vortecs. That would still work well. Adam Last edited by firestone; 05-19-2009 at 03:16 PM. |
well, junk yard says 50 bucks each, and I did reply to the guy with double hump heads for 400. Ill offer him 300, because, thats all I have. As far as intake, what should I get?
I hear about the Performer RPM. Will the double hump heads+performer RPM, and what cam do I need? |
Many pick-a-part and even most traditional junkyards have heads for flat prices. If you want the best street head for your dollar, go Vortec. Double hump heads were pretty good by 1970 standards, but Vortecs will offer much more potential without sacrificing torque.
Add in the fact that (depending on the cam) you can get away with as much as 9.5:1 on 87 octane, use less ignition lead, pollute less, and lower your cholesterol, its a no-brainer. Many times people complain about the .470" lift max on vortecs, or the fact that you have to buy an intake, but I don't really much care. For a couple hundred you can buy the springs/retainers for .550" lift (and if you're using an aftermarket cam, you would need springs anyway). Intakes are cheap, even if you have a brand new intake, sell it and buy a used Vortec intake. |
If you're only after 300hp you can use just about any head you find. I would shoot for 9:1 compression and the smallest cam you can use that will still get you to your goal (which depends on the rest of the combo). smaller cams work better on the streets, and if you only want 300hp you can build that thing using low cost parts and run it on 85 octane. I would go with the "double humps" if you can find a rebuilt set for around $250 or less- which shouldn't be hard. They aren't as good as Vortecs but are a little more budget friendly.
Alright, so Im learning that Vortecs are the way to go, and since I see lots in the pick and pull, I think Ill go that route. Now, Edelbrock has a vortec rpm intake (7116) thats in the price range. I guess all I need now is which cam? What about pistons? I thought It would be a great idea to go ahead and boar .030 over while we were at the machine shop, so naturally I know Ill need new pistons. Wheres a good deal in that aspect? will a boar .030 over mate up to the vortecs? one more question: whats a good year range and vehicle to pull the heads from? I know so many questions, but thanks to everyones imput already. I just got back from a tranny shop and the guy kept talking about this and that, but he was running a alchol dirt track car, and really I couldnt get any applicable knowledge from him. So, YOUR ALL I GOT HOTRODDERS! -Jay |
Good choice, Jay. Let's talk about the vehicle and its intended use. What car, and how are you going to use it? How about axle ratio, transmission, and what fuel you want to use?
That same 300 hp can be had with less cam, less octane, and more future potential with Vortecs compared to the humps. |
Well, I have but 3 months till I head out to Iraq again, and I wanted to have a little fun before I left. As you can tell from my limited knowledge, building a hot rod is new to me. I just got a 1974 C-10. It has a TH400, 12 bolt with 3.73 gears. Stock disk brakes. I want it to be a fun truck to drive to work on fridays and do burn outs in my shop parking lot, before going to track nights. So, a good cruzer, but ready to tear up some road! Its a long bed, but I may junk the bed, just to lighten it up and put a posi in it. So, I need a pavement killer for a few months! PLEASE HELP GUYS! Oh, and about them vortec heads, thats what I have in my 1979 Monte Carlo, on a 350, and in my 05 Silverado... Totaly forgot. If all else fails, ill rob that engine for a while... not from the silverado!!! Wife will kill me! -Jay |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| Why spend money on heads? | F-1Rodder | Engine | 8 | 03-07-2008 12:09 AM |
| junk yard turbos | leldai73 | Engine | 8 | 06-08-2007 07:44 AM |
| Junk Yard Dogs | tbelltim | Engine | 1 | 05-26-2007 01:08 PM |
| "57" 283 build ideas.using 539 heads | mark anderson | Engine | 13 | 12-07-2003 04:58 PM |
