What kind of compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2008, 09:42 PM
Last journal entry: Cowl Panel RUST!
Im looking for a compressor to shoot mostly primer and por 15. i was wondering what i should be looking for? i have a budget of around 300 and dont know if that will be enough for what im looking for.
thanks for the help
Old 12-14-2008, 10:14 PM
You can buy a compressor for $300 but not much of one unless you run onto a real deal on a used one, however for about $100 more you should be able to get one twice the size of the one that the $300 will buy. Look around and you should be able to find a sale on the very popular Campbell Hausfeld, Husky, US General or several other brands of essentially the same compressor. This will be a 60 gallon vertical tank with a 15 AMP 3 /12 HP motor (it may be rated as high as 7 HP but at 15 AMPs that is BS!) and 2 cylinder single stage compressor, not the best performing compressor you can buy but for the money it's not too bad either. That extra $100 or so will make all the difference in getting a decent performing compressor that you can actually use for something vs a $300 tire pumper.
Now about that POR 15!
Old 12-15-2008, 03:26 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
One really needs 10-15 cfm at 100 psi to spray with..anything else will be frustrating.wait a couple of paydays and get one that will support commonly used air tools..you will not regret it..
Sam
Old 12-15-2008, 09:19 AM
302 Z28's Avatar
And do not buy any of those direct drive POS, you will have to wear hearing protection if your within 100 feet of it
Vince
Old 12-15-2008, 10:29 AM
Vince
And even if you don't go deaf you will probably die of old age waiting for it to build up pressure!
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Air compressor breakin how important? SteveU Garage - Tools 2 08-16-2006 06:31 PM
What type of compressor? Skipr Body - Exterior 1 05-29-2006 08:00 PM
Picked up a "new" compressor and torch gator412 Garage - Tools 18 05-19-2006 03:13 PM
compressor questions... Eddie N Body - Exterior 6 04-22-2003 06:35 PM
