What kind of horse power will I get????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2005, 09:32 PM
How much horsepower will I get from this engine?
327 Large Journal Block .40 over
Steal Crank
TRW forged pistons 9.96 comp ratio
Speed Pro Moly rings
Michigan 77 rod and main bearing
Edelbrock Proformer RPM cam
Basic Operating RPM Range: 1,500-6,500 RPM
Intake Duration 050 inch Lift: 234
Exhaust Duration 050 inch Lift: 244
Duration at 050 inch Lift: 234 int./244 exh.
Edelbrock Proformer RPM intake
Edelbrock PRoformer 750 cfm carb
Pete Jackson noise gear drive
World Torquer Heads
.500 lift intake 221 cfm / exhaust 166 cfm
.400 lift intake 205 cfm / exhaust 156 cfm
Manley Swirl polishied 2.02/1.60 valves
67cc combustion chamber
3/8 studs
Comp Cam roller tip rockers and lifters
350 turbo street/street transmissions
Old 02-17-2005, 09:39 PM
280zxWith305's Avatar
<--- Gas Bootlegger
too big of a carb for that engine.. use a 600-650cfm or so.. but im guessing with the right carb around 350 hp.. maybe 375..
Old 02-17-2005, 09:42 PM
Yah, I wondered when I bought the 750 cfm carb if it was to much. Alot of people have said that it was to big of a carb. Thanks for the information.
Old 02-17-2005, 10:15 PM
<--- Gas Bootlegger
dont feel bad.. i bought a edelbrock 600 for my 305.. then decided to build a 383 which makes my carb too small.. if your intrested i'll trade ya.. and make up the difference in price.. then u getta carb and some cash.. i getta carb w/o having to hunt someone down to buy mine
Old 02-17-2005, 10:38 PM
280zxWith305, I sent you a PM.
Old 02-26-2005, 05:16 AM
willowbilly3's Avatar
Last journal entry: Body mods
The large journal 327 block is the same thing as a 350 block. I am a little out of the loop but I didn't think Chevy ever made a steel large journal 327 crank, but I could be wrong. In my opinion, I would build it a 350 or 383 since cubic inches =horsepower. That being said I actually like 327s better than 350s but two of the advantages to running a 327 are using the small journal block for less bearing speed and because all small journal 327 cranks were steel anyway.
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
300 horse power 355 70 nova Engine 9 02-19-2003 11:38 AM
Horse power and Torque HELP PLEASE!!! 70 nova Engine 2 02-18-2003 10:57 PM
pulleys does it give horse power or torque 70 nova Engine 2 02-18-2003 10:59 AM
anyone know anything about putting power brakes and power steering on a '63 impala SS Benni520 Suspension - Brakes - Steering 0 10-14-2002 01:22 PM
