What kind of material is this?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2010, 05:20 PM
Last journal entry: comming along
I know it might be kind of hard to see, but I am not sure what kind of material this is. I used that fabric paint on them, but it doesn't look very good. I need black seats. They are from a conversion van. There are two armrests for the capitains chairs. I would like to cover both front seats, and the bench seat in the back of a 37 Ford Tudor. Thanks.. Al
ID:	49062   Click image for larger version
ID:	49063   Click image for larger version
Old 10-21-2010, 11:55 AM
DanTwoLakes's Avatar
Wiki Edits: 22
This type of fabric is called Velour. The fabric itself is probably made of nylon, polyester, olefin, or acrylic. It would be automotive grade, so it would be pricey.
Old 10-21-2010, 01:55 PM
So what would be a good looking not so pricey fabric for the 3 seats?? Still going to be black..
Old 10-21-2010, 03:40 PM
http://www.midwestfabrics.com/index....t_detail&p=706
I found this. It is a nylon poly blend.
Old 10-21-2010, 03:54 PM
Wiki Edits: 22
That is contract fabric, which makes it very durable, and suitable for offices, waiting rooms, etc. What it is not is pliable, soft to the touch, and easy to work with for anything other than flat panels and simple furniture.
This is what you're looking for, there are three different patterns and you could mix and match two of them. CLICK HERE
I understand that you're trying to keep the cost down, but you only need about 7 or 8 yards for your seats and this stuff would be $140 or $160. Don't be penny wise and pound foolish with the fabric you choose. Get some samples first and see what the difference is.
Old 10-21-2010, 04:01 PM
So Dan.. What is a good fabric?? I would rather stick with a fabric over one of the leathers, or faux leathers.. Al
Old 10-21-2010, 04:09 PM
Wiki Edits: 22
Look at my last post, I put a link in there for you.
Old 10-21-2010, 04:22 PM
http://www.perfectfit.com/15994/1570...Fabric-54.html
Found this also.
Old 10-23-2010, 06:02 AM
http://www.perfectfit.com/15994/1567...Fabric-54.html
Found velour..
Old 10-23-2010, 07:29 AM
Wiki Edits: 22
Both of those fabrics are good choices.
Old 10-23-2010, 12:12 PM
Question Dan.. Which way?? I have seen headliners on the roof, or on the hoops.. I have the hoops, but would there be more room having it glued to the roof?? Thanks.. Al
Old 10-23-2010, 02:10 PM
Wiki Edits: 22
No, the headliner isn't glued to the roof, it would still have to be about 1 1/2" to 2" below the roof one way or the other.
Old 10-23-2010, 03:02 PM
I found a couple of pictures out there this morning. Which way do you think I should go?? I have those bows.. They were laying on the floor when I bought the project, so I don't know what goes where. Though in the book I am reading.. I skipped to the back and it shows how 1x2's were used to make a framework that paneling was screwed to. I have found a place that sells headliners, and there is one for my 37 Tudor there. I don't think I could do something like that. Al
Old 10-23-2010, 05:16 PM
Wiki Edits: 22
Buy the headliner and hire someone to install it.
Old 10-23-2010, 05:33 PM
Ok. Comes with instructions.. Al
NOS headliner material quality issues junkyardjeff Interior 3 09-13-2009 12:14 PM
Help with why my upholstery material is ripping while sewing Shweaty Interior 3 07-09-2009 10:03 AM
marking material benchracer1 Interior 7 05-17-2009 09:58 PM
What Material Do I Need To Sandblast Under My Car ? ? ? SCHOONER Garage - Tools 5 05-11-2006 01:57 PM
Most durable material for interior?? HotRodMan Interior 5 05-02-2003 10:35 PM
