What Kind of paint is on a Lincoln LS - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2004, 09:46 PM
New Member
Does someone know what kind of paint is on a 2000 black Lincoln LS. Is it a an enamel basecoat clearcoat or a lacquer bawecoat clearcoat paint. I need to paint my front bumper and I dont want to use the wrong paint as a lacquer will peel an enamel paint
Thanks
Old 03-25-2004, 10:00 PM
BOBCRMAN@aol.com's Avatar
The factory OEM paint really isn't an enamel or a lacquer, most use waterborne finishes and dryers. Most of the repair paints are enamel or urethane based. In the US it is almost impossible to buy lacquer based paints. except for touch up spray cans and the solvent in them won't react with most factory finishes.
Old 03-26-2004, 10:19 AM
New Member
So Bob what kind of paint should i use. I want to try to get as good a job as possible with a spray can. If i use a primer will it be ok. let me know
Thanks
Old 03-26-2004, 11:03 AM
Spray can primers and paints are ok for minor touch ups
Old 03-26-2004, 04:46 PM
Sandflea427SS's Avatar
Anything with a throttle
If you do mix a base/clear for your touch-up don't forget to get the additive for bumpers. I can't remember what it's called but the paint used for soft parts gets a few ounces to make sure the paint is flexible!
Old 03-26-2004, 05:57 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
If you want it done RIGHT either take it somewhere or you will have to have the equipment to do it yourself. If you do it with a spray can it will not match and it will look like it came out out of a spray can. If you really don't care about the looks then just hit it with some Dupli-Color spray bombs.
Kevin
