What kind of performance can I expect to get out of this combo ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2013, 06:34 PM
USA_CHEVROLET_1's Avatar
350 four bolt main
Turbo 350 Transmission
New GM Vortec Heads
Eglin 922P cam (Lift: .443/.465, Duration: 288/298)
Champion Series 331 Vortec Intake
Holly 650 four barrel carb
MSD 6AL Ignition
Headers / Glasspacks
12 bolt 3:31 posi
2000 stall torque converter
Any idea what kind of horsepower that might generate ?
Thanks
Old 02-12-2013, 07:33 PM
hp rating
The horsepower is difficult to guess without some other details. You didnt mention what the compression ratio of your pistons were....flat top? Depends also on the combustion chamber size. estimating a flat top piston with 64 cc heads and that cam...you're probably around 275 hp
Old 02-12-2013, 07:45 PM
Thanks for the reply.
I'm hoping that your estimate is a little low. The motor was rated at 240 Hp from the factory witht a 2 Barrel carburator. I would think that just adding a 4 barrel carb and headers would have gotten it to the 275 HP. The old heads were stock 882 76CC smog heads and the Vortecs are 64 CC. Also the heads have the Z28 springs installed.
The pistons are the stock flat top pistons (8:50 to 1) I hear the vortecs with proper gaskets will get it to around 9:50 - 10:00 to 1 compression)
Old 02-12-2013, 08:24 PM
vinniekq2's Avatar
35 plus hp is a good gain?If someone says 300 will you feel better?Im conserned that elgin cam might be a dud? what are the angles and 050 duration?That intake,what is it designed to do?
Old 02-12-2013, 08:40 PM
No, someone just saying 300 hp wont make me feel any better. I was just stating the the motor was probably at 275 with the 4 barrel carb, ignition, intake and headers...Guess that adds nothing huh ??
I'mm just trying to get a reasonable estimate.
Anyway, here are the specs for the cam:
Lift: .443/.465
Duration: 288/298
Duration @ .050": 214/224
Lobe Separation: 112 LC
As far as the intake - Idle to 5500 RPM
I'm just lookin for something that has really good low end torque....stop light to stop light fun !
Old 02-12-2013, 08:53 PM
vinniekq2's Avatar
I dont like the look of the cam specs.Thats just my opinion.If the engine is carefully blue printed with those parts,Im sure it would go high 13s or low 14s.
I would use a bigger carb and a cam with a lobe separation of 110,maybe.I would use more lift too and a little more duration.
what do your heads flow for CFM?
Old 02-12-2013, 08:59 PM
horsepower
I was estimating on the low side because I didnt know some of the variables. I too was a bit concerned with the cam choice. Seems a bit meek to me. The vortec heads should help with compression, but the carb could use an upgrade. I still think that with everything in order that 300 hp is about peak.
Old 02-12-2013, 09:03 PM
The cam I selected specfied great low end torque...dont plan on taking it to track...just something to raise a little hell on the street
Old 02-12-2013, 09:09 PM
vinniekq2's Avatar
cam (elgin)
do you know anyone using an Elgin cam?what the book says and what it does hopefully match
Old 02-12-2013, 09:26 PM
BigEd36's Avatar
That Elgin cam is .443/.465, 214*/224* @ .050", 112* LSA 107* ICL. It's basically the same cam as the Summit K1103 and the #24502476 cam used by GMPP in the 350HO 330HP crate engine and the CT350 350HP circle track crate engine. They use stock 350 short blocks with Vortec heads, so USA_CHEVROLET_1 has pretty much duplicated that engine so I believe he should be in that area for HP.
Old 02-12-2013, 09:27 PM
Banned
340ish hp and about 410ish ftlbs. Its a typical "RV cam" and will definitely have that torque you're looking for.
For a solid street runner its a pretty good combo, you may want to consider 1.6 rockers and you'll need to get your carb and ignition tuned for it, but it will be a good street runner, not bad for stop light races either.
Old 02-12-2013, 09:45 PM
Thanks for the replies. I originally planned to use the stock stamped self aligning rockers, but maybe I need to rethink that. also, what type of gasket to use to get the compression up ?
what performance can i expect from my 302 ford? 427feracer Engine 24 01-08-2010 01:58 PM
what kind of times can i expect? 1974 gto Engine 6 09-11-2005 01:16 PM
what kind of trany should i expect? hotrod66_57 Transmission - Rearend 5 08-12-2004 09:57 AM
what kind of hp can expect from this combo? 7seconds Engine 0 12-01-2003 10:15 PM
Should I expect to thit the 400 HP mark with this combo? RANGER_MIK Engine 23 12-01-2003 04:18 AM
