Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 02-28-2003, 05:08 PM
CAMARO CAMARO is offline
New Member
Post what kind of primer
Hello to all. I'm looking for some sound advice here. Me and a friend have been working on a frame off resto on a 68 camaro for about one year to the day. the car has been bare metal for most of the time. The body work will be done in a couple months. The shop we're in is fairly dry, and we have not experienced any "visible" rust to speak of. The car is going to be driven alot and durability is my main concern. How should I prep right before primer and what primer do I use-Epoxy, Veriprime, sealer, buildable, sandable, nonsandable? I'm lost in a sea of primer. S.O.S
[ February 28, 2003: Message edited by: CAMARO ]</p>
Old 02-28-2003, 05:53 PM
paintman1 paintman1 is offline
Post re: what kind of primer
If the car has say for a long period of time, I would scuff over all the bare metal with some sandpaper to sand off the rust that has started. It may not be visible but it is there. Then clean the surface with a good wax and grease remover. Surface must be clean. A good old wise bodyman once told me "you can't paint over a powdered donut". Allow to dry thoroghly. Spray on one good coat of a good etch primer. Let dry. Then spray three coats of a good urethane sandable primer. This you can block out good and if needed you can reprime. Hope this helps . good luck
Old 02-28-2003, 06:00 PM
New Member
Thanks for the tips. From now on there will be no powdered doughnuts allowed in the shop! But seriously, thanks.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
