what kind of rear end should i go with?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2006, 05:09 AM
i just purchased a 1984 cutlass supreme, with a 350 and a 350 turbo tranny! Both soild, motor is out of a Z28 camaro. i have a bone stock rear end in it, what kind of rear should i put in, or what can i do to make it more top end. i'm looking for quater mile speeds not long distance speeds, please HELP!!!!
Old 07-10-2006, 05:30 PM
re rear end problem
You stated that you wanted more top end and quarter mile speed.You can't have the best of both. You need a lower gear for quarter mile speed, like 4:11 or 4:10. For top end you probably need something like 3:55. Just to give you and Idea, my 70 model ford truck has 3:73 and at top speed of 140 mph, I am turning about 5400 rpms. I have a good take off and a good top end, so I will stick with the 3:73s. You can install a good stall converter, like 2400, and this will give you the take off and the quarter mile power, assuming that you have a good power engine behind it. Hope this helps.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
What kind of rear end does my 64 Impala have? Uber Transmission - Rearend 8 07-17-2004 07:00 AM
dodge challenger in need of rear end advice. Journier Transmission - Rearend 0 05-28-2004 10:23 PM
