What kind of rearend is in a 2001 Silverado? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2003, 03:38 PM
Muscle car fan
My dad picked up a 2001 silverado this year but it didn't come with a posi or traction device, so he was wondering what was available. So my question to him was, what kind of axle is it, and he doesn't know, and i don't know chevs, so i'm SOL.
it's powered by a the 4.6L V8 if that helps
thanks a bunch guys
'74 Gran Torino Project
351W, c6 trans, 9"
Old 12-28-2003, 04:00 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Is it a 1/2, 3/4, or 1 ton truck?
Old 12-28-2003, 04:02 PM
Muscle car fan
1/2 ton
351W, c6 trans, 9"
Old 12-28-2003, 04:18 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
GM CORP 8.5" REAR AXLE - 30 SPLINE 99 & UP
(STANDARD-pinion) REAR
Number of cover bolts: 10
Number of axle splines: 30
Diameter of ring gear: 8.5"
Number of ring gear bolts: 10
Pinion Shaft Diameter: 1.625"
Pinion Splines : 30
Low Case Ratio : 2.73
Old 12-28-2003, 04:24 PM
Muscle car fan
Pinion Splines : 30
wonderful, thank you
351W, c6 trans, 9"
