What kind of rings to get? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2003, 09:26 AM
lord's Avatar
I don't know my compression, i asked in another thread and i'll ask again here. 64 cc chamber, flat top pistons with little grooves for valves, the piston tdc is about 1/4 inch below deck. 350 block bored .030 over. anything else you need to help me figure comp?
Anyways, i tore the motor down to replace the piston rings, and was wondering what kind would be best to buy. the motor is 350 with double hump heads, mild cam, I want power.
Old 10-02-2003, 07:23 PM
BOBCRMAN@aol.com's Avatar
Use plain cast iron rings such as Hastings 139 on a used bore, if there is no taper or wear you can use a moly ring, do not use a chrome ring on a used bore.
Old 10-02-2003, 07:48 PM
roys63's Avatar
Re: What kind of rings to get?
[QUOTE]Originally posted by lord
[B]I don't know my compression, i asked in another thread and i'll ask again here. 64 cc chamber, flat top pistons with little grooves for valves, the piston tdc is about 1/4 inch below deck.
Are you saying that your pistons are a 1/4" below the deck of the block? If so you have the wrong rods or pistons or both in this motor!! This must be changed !!
Old 10-03-2003, 06:59 AM
lord's Avatar
maybe its more like an 8th, what should it be?
Old 10-03-2003, 04:22 PM
roys63's Avatar
The deck height can be at 0 or.010,20 depends on the heads and head gasket to work out your compression ratio, if you want power the piston needs to be a bit closer to the head . What is the casting # of your crank and block? You need to measure your deck height better to be sure. Someone else may ring in on this.
Old 10-13-2003, 08:24 PM
lord's Avatar
yeah, i was wrong, i was looking at the marking on the cylinder wall and I figured that was where the piston topped out. But that is just where the piston ring tops out so the deck heigth should be normal.
