what kind of timing chain i should get?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2011, 05:01 PM
got a stock 305 87-92 style block, could i get a double roller timming chain from auto zone and be ok??
Old 07-29-2011, 05:51 PM
DoubleVision's Avatar
It depends on if the block is a roller cam or flat tappet. If it`s flat tappet it`ll be a bolt on. If it`s a roller cam it`ll be somewhat different.
Old 07-29-2011, 08:29 PM
pretter sure its roller cam
Old 07-29-2011, 09:11 PM
This is about the cheapest one I found on a quick look.
http://www.summitracing.com/parts/EDL-7801/
Old 07-29-2011, 10:05 PM
so a double roller will work with what i got? does it matter what intake and carb i will be running?? i want to upgrade to a edflebrock performanse intake with a edelbrock 600 carb
Old 07-30-2011, 05:48 AM
TroyBoy's Avatar
Psychomotors
You will be fine with a double . The timing chain connects the crank to the cam-it doesnt care about the intake and carb,lol.
Old 07-30-2011, 09:25 AM
o ok lol thanks i know it matter some times what other parts are on the motor ,im still new to this sorr if i sound stupid
Old 07-30-2011, 04:37 PM
TroyBoy's Avatar
Psychomotors
No worries Hank. The only stupid question is the one unasked,lol.
Old 07-30-2011, 05:41 PM
thanks off subject though,i replaced my oil pump,thermastat,water pump,valve cover gaskets,plug/wires,cap/rotor, everything stock,would it be ok it i upgraded my intake to a edelbrock performance hi rise and a edelbrock 600 carb?????
Old 07-30-2011, 05:48 PM
cool rockin daddy's Avatar
Go for it! That is usually the first bolt on modification people do, a performance intake and carb.
Old 07-30-2011, 06:01 PM
cool so if i did go with this combo i wouldnt have to do anything else to the motor inside wise?
Old 07-30-2011, 06:03 PM
it wouldnt be to much or overboard for a 305??
Old 07-30-2011, 09:19 PM
What you want to do is called a "bolt on" modification. It means you are just bolting parts onto the engine, not into the engine. Just do it. Make sure you understand thoroughly how to tune and adjust whatever carb you get. They need to be adjusted to what your engine wants.
Old 07-31-2011, 10:32 AM
k thats what im going to do,but would the hi rise performer be a good choice??
Old 08-07-2011, 09:58 PM
so i should buy this 1 right??? i will be buying 1 within this week so i dont have to look for another brand or style? just this and the gasket set right
Need help with timing chain super_silent Engine 8 06-27-2008 02:32 AM
Timing chain "70" Cougar Engine 18 02-17-2008 02:25 AM
Help with timing Chain and timing cam install LXZ590 Engine 7 12-08-2006 10:01 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
Timing gears vs double roller chain timing chain Jag Daddy Engine 12 05-24-2003 10:22 PM
