what kind of transmission? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2007, 11:05 PM
what kind of manual transmission(low gear then 3 speeds) comes in a 1984 chevy 2500 and does anyone know the ratios? or where i can find them?
Old 08-24-2007, 11:38 PM
4spd
I have the same kind of tranny in my 76' Scotsdale....that granny gear will pull a house down...
Old 08-24-2007, 11:58 PM
strummin67's Avatar
Violating consensual reality
Last journal entry: It tows!
You should have the Muncie SM465. It was used from '68-'91 in 1/2 ton to 1-1/2 ton trucks. Check out this link: http://www.novak-adapt.com/knowledge/sm465.htm
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
How to disengage transmission from block? El Raton Transmission - Rearend 10 11-26-2005 07:55 PM
I tried Lucas Stop Slip Transmission Additive : My Results Ghetto Jet Transmission - Rearend 8 09-07-2005 06:12 AM
Engine and transmission mounts cucumber1949 Hotrodding Basics 1 08-07-2005 08:15 PM
Transmission Switchout Hands87 Transmission - Rearend 0 09-21-2002 07:24 PM
