What kind of transmission do I have? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2007, 10:21 PM
New Member
I bought a 37 Olds that the owner told me had a late 70 Olds 350. After I started researching the numbers on the engine, it turns out it is a 307. It also has a 83 Olds front clip. I'm assuming that the engine was also out of the 83 olds. So my question is, what was the transmission that came in a 83 Olds? How do I identify it? Is it an overdrive transmission. If it is I will just keep it because I have since bought a 76 350 Olds / 350 turbo to drop in the car. Any help would be appreciated. With gas prices, I would prefer the trans. with an overdrive...
Old 11-27-2007, 10:39 PM
j.d.brown.042964's Avatar
406 Caprice:Rust Never Sleeps!
If you go to the hotrodders knowledge base;Transmission-Rearend section you can find all sorts of links to sites giving identification information. Most likely if motor is 307 (olds division) it would be 700r4.
200r4's and 700r4's use a Throttle-Valve ("T.V.")cable that runs from carb linkage to side of trans and controls line pressures/shift points,etc..
On the knowledge base look for references to "pan identification" as that is usually a good means of identification .(shape/# of bolts) PS-MANY GOOD PEOPLE ON HERE W/LOTS OF KNOWLEDGE AND EXPERIENCE {much more so than I, at least!) -Jim
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
I tried Lucas Stop Slip Transmission Additive : My Results Ghetto Jet Transmission - Rearend 8 09-07-2005 06:12 AM
Engine and transmission mounts cucumber1949 Hotrodding Basics 1 08-07-2005 08:15 PM
transmission oil type. TVR383 Transmission - Rearend 3 06-05-2005 09:28 AM
Transmission Switchout Hands87 Transmission - Rearend 0 09-21-2002 07:24 PM
