What kind of welder?
1 Attachment(s)
OK all you guys with sharp eyes and good welding skills what kind of welder was used to weld this?.......Now a little info, I welded this and was surprised when I wire brushed it how it looked, so lets see if anyone can tell me what welder I used. I'll give it a few posts,then I'll post pics of the welder. :D
Kenny |
oxy accet torches? looks like good old gas welding
That can be done with a MIG with the right size wire, the right heat and technique,,
Sam |
Getting close..........
Kenny |
I'll nominate a T.I.G. welder from the lack of welding splatter!
Looks like plain old stick welding to me.
Trees |
2 Attachment(s)
This is what it was welded with......A surplus store refurbished wire welder that I paid 45 bucks for, and the wire that was used.I have put ramp pins on 5 trailers to hold the ramps in place and to my surprise most all of the welds turned out like the one in the pic.....
Kenny |
In addition I have been told and read post s all over the net how much a piece
of junk that flux core welders were and how bad they were about leaving splatter. The only time that has happened to me was on some rusty metal that I did not clean good enough.......Surprised me too!!! Kenny |
Good old flux core e70t-11, this is similar (I use 212mp) to the same wire I weld with at work when I am outside (and in a hurry 5/64 diameter). I always found that that wire will make a very nice vertical too when you get the heat just right. The only drawback about the 211mp you use is that after you weld (multipass) over 1/2 is that the elasticity is lost :smash: , the 212 is good for an 3/4 to inch thickness. I have used this for piling and other structural steel with great success an I always found that the 212mp has more spatter than 211.
:) Clean is the ticket to any welding! Nice job. I've used the little flux wire welders before for Field repairs on farm stuff and had no complaints with them. Hard to get stuff prepped when your trying to get a crop in so Field stuff ain't pretty around here just functional.
Tony |
1 Attachment(s)
Thank you! for all the replies and kind words . I need to post this also,my brother-in -law saw this post here at my home last night and said that people might get the idea that the weld was made horizontal ....sorry I did not think about that all I thought about was posting the best pic I had ,so here is the pic that of the weld in it correct orientation. I apologize as I was not trying to miss lead any one .
Kenny |
I have been meaning to pick up some flux core just to see how it works. I have never welded with it and want to give it a try.
Of course your skills is what made those welds so nice. A less skilled individual with the same "junk" welder and wire isn't going to produce something so nice. Brian |
i did my whole frame and a lot of the sheet metal mods with a 110v lincoln flux core welder that i picked up at hd for $300. it's always ready and i have never run out of shield gas...
those that have never used flux core welders are the main distractors to it's use. http://i306.photobucket.com/albums/n...e/P1020013.jpg http://i306.photobucket.com/albums/n...e/IMG_0158.jpg |
a less skilled individual with any piece of equipment is likely to get sub-par results. |
| All times are GMT -6. The time now is 07:06 PM. |
