-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   what kind of welder? (http://www.hotrodders.com/forum/what-kind-welder-70847.html)
ratop slacker 09-25-2005 04:07 PM
so's im thinking of gettin a mig welder. what is the best size for cuttin, z'ing, or just a bunch of stuff to do to a car u kno...
Centerline 09-25-2005 05:16 PM
You won't be cutting with a MIG welder. For that you need a plasma cutter.
ratop slacker 09-25-2005 06:15 PM
sory, i just ment choping and suff, did't mean 2 say cutting. but i guess what i'm trying to say is, what kind of mig welders work for you guys?
Henry Highrise 09-25-2005 06:32 PM
Well you won't be chopping with a mig welder either. Tell us what your welding needs are...Are you going to use it for body work? Or do you need something to work on frames with? Or both.
ratop slacker 09-25-2005 07:15 PM
i just ment reattaching it by chopping. you can use a mig for that right? but anyway, i would prabably be doing both bodywork and work on the frame.
OneMoreTime 09-25-2005 08:57 PM
Miller or Lincoln SP175 or equivalent..get the goodone as you will using this puppy for years..then get yourself a whole boxfull of metal squares..we call these coupons and when you can get those welded and do a good job then you may weld non-critical stuff on a car..
Practice practice practice and take a course at the local vo-tech school..helps a lot..
OMT
Centerline 09-25-2005 08:58 PM
For that work most any of the smaller MIGs will do just fine. For basic auto work I would look for one that can weld up to 1/4" steel just in case you ever need to do frame work.
