what kind of welder? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2005, 03:07 PM
so's im thinking of gettin a mig welder. what is the best size for cuttin, z'ing, or just a bunch of stuff to do to a car u kno...
Old 09-25-2005, 04:16 PM
Wiki Edits: 49
You won't be cutting with a MIG welder. For that you need a plasma cutter.
Old 09-25-2005, 05:15 PM
sory, i just ment choping and suff, did't mean 2 say cutting. but i guess what i'm trying to say is, what kind of mig welders work for you guys?
Old 09-25-2005, 05:32 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Well you won't be chopping with a mig welder either. Tell us what your welding needs are...Are you going to use it for body work? Or do you need something to work on frames with? Or both.
Old 09-25-2005, 06:15 PM
i just ment reattaching it by chopping. you can use a mig for that right? but anyway, i would prabably be doing both bodywork and work on the frame.
Old 09-25-2005, 07:57 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Miller or Lincoln SP175 or equivalent..get the goodone as you will using this puppy for years..then get yourself a whole boxfull of metal squares..we call these coupons and when you can get those welded and do a good job then you may weld non-critical stuff on a car..
Practice practice practice and take a course at the local vo-tech school..helps a lot..
OMT
Old 09-25-2005, 07:58 PM
Wiki Edits: 49
For that work most any of the smaller MIGs will do just fine. For basic auto work I would look for one that can weld up to 1/4" steel just in case you ever need to do frame work.
What kind of welder do I need? just another car guy Garage - Tools 10 07-22-2008 09:09 AM
is this welder any good?? michiganjoe Body - Exterior 10 11-23-2006 07:57 AM
Hobart Champion 4500 welder sotxpanrider Garage - Tools 2 03-06-2005 09:07 AM
Seeking MIG welder recommendations Slipangle Garage - Tools 6 10-20-2004 09:04 PM
Arc welder ~VS~ Mig Welder ChrisMiddleron Electrical 15 07-08-2003 07:31 AM
