What kind and whats wrong with my tranny? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2006, 09:08 PM
I have a 2001 dodge ram 1500 ,360,4wd,3speed +overdrive automatic tranny. Today I lost reverse. Also when I stop, it doesnt always shift into first, so I shift it down myself. It has been like this for 4 years.Right before I lost reverse, it wouldnt shift into low manually,the lever feels right but it started in second. The indicator lines up perfect. PLEASE HELP?
Old 08-18-2006, 08:04 PM
Consider your own comments...
This trans has internal problems that will require a rebuild.
Sound like more than one issue, but there are front clutch drum issues that will cause loss of reverse. This is an electronically controlled trans. Have the truck scan checked. Default for this trans is 3rd, but if there is internal problems, 2nd could end up being the effective default ratio....
