-   -   what kinda muncie (http://www.hotrodders.com/forum/what-kinda-muncie-86675.html)
bigtim 04-11-2006 08:12 PM
what kinda muncie
i have a muncie 4 speed from a 64 chevelle ss and don't know which it is m20 21 22 and its been sittin for about 10 years with no fluid woul d it still be good :nono:
johnnya 04-11-2006 08:31 PM
Question 1.
I would say you have about a 90% chance that it's a M-20 (wide ratio)
There have been many discussions here regarding how to identify the different Muncie's.
A search would probably turn up ample info.
Question 2.
I think the innerds will be OK. You could remove the side cover and inspect for rust.
JA
302 Z28 04-12-2006 05:06 AM
Go to www.4speeds.com
Vince
k-star 04-12-2006 06:07 AM
muncie
Post all the numbers that are on the tail housing, main case, side cover.
If you look at the front of the transmission, Under the input shaft there is another shaft that is fluch with the case. Measure the diameter of that shaft and let us know what it is...
I would bet that if the trans sat for 10 years with no oil it it there is probably going to be issues....
Keith
bigtim 04-13-2006 06:16 PM
2 ring 10 spline
side cover 3884685
main case 3925660
patent no. 388336
p8k01
tail shaft 385784
i pulled the cover off and is very very little rust and all gears still turn and engage :evil: any body know what kind it is
k-star 04-17-2006 04:50 AM
trans
Its a 1968 M20.. It was built in sept of 67 for the 68 model year. It has the correct side cover and tail housing. That transmission has a 1" cluster pin..
All-in-all a good transmission to have... If it's clean and the sincros are not bad then i guess you have a winner.... Remember you need to have the transmission and the cover in the second gear position to get the side cover back on...
Keith
302 Z28 04-17-2006 05:42 AM
Originally Posted by bigtim
2 ring 10 spline
side cover 3884685
main case 3925660
patent no. 388336
p8k01
tail shaft 385784
Evidenty you did not visit www.4speeds.com. You would be able to identify the trans with the information there :rolleyes: .
Vince
